Civic swap not cranking or clicking
Old Jan 3, 2007 | 11:03 PM
FuNkDrSpOt's Avatar
Default Civic swap not cranking or clicking
I have a '97 Civic w/ a b18c1 swap and I had to reset my SRS light and to wire some stuff into my ECU today. I finished and now my car doesn't start.
The symptoms:
----doesn't crank and doesn't do the continuous clicking over and over, all that happens is a single click under the dash and power simultaneously goes out in my climate control ( goes out like flicking a switch off, not a slow dim ).
Items to rule out:
----Battery. My car plays my stereo perfectly, it just doesn't start.
----ECU. Even with the ECU unplugged, my car doesn't crank like it should
Possible causes of my problem:
----I could have crossed ECU pin# 10 and 11.
----I could have unplugged some crap under the dash, seriously, my dash is a ******* nightmare and I had to move a lot of crap around JUST to get to the SRS plug.
----anything else YOU can think of......maybe I shorted my starter solenoid or relay or some ****.
Help please, I gotta get to work at 2pm and I damn sure don't want to ride my bike.
Old Jan 4, 2007 | 01:47 AM
FuNkDrSpOt's Avatar
Default Re: Civic swap not cranking or clicking (FuNkDrSpOt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">I have a '97 Civic w/ a b18c1 swap and I had to reset my SRS light and to wire some stuff into my ECU today. I finished and now my car doesn't start.
The symptoms:
Items to rule out:
Help please, I gotta get to work at 2pm and I damn sure don't want to ride my bike.</TD></TR></TABLE>
nightly bump
Old Jan 4, 2007 | 03:07 AM
FuNkDrSpOt's Avatar
going to bed, if you read this after this point, please bump it for an answer, even if you may not have one yourself. Thank you.
Old Jan 4, 2007 | 03:43 AM
BlakeJ53's Avatar
Make sure ALL of your ground are hooked up. If they are not all snug the car wont crank. I didnt have my vavle cover ground hooked up and it wouldnt crank.
Old Jan 4, 2007 | 05:01 PM
FuNkDrSpOt's Avatar
Default Re: Civic swap not cranking or clicking (BlakeJ53)
I figured it out. One of the relays under the dash was knocked out of socket. I'm quite surprised that no one has used this relay as a kill switch.....something to think about.
Bryan08
Honda Civic (2001 - 2005)
Aug 29, 2017 07:14 AM
SuperTuner12010
May 6, 2009 01:40 PM
97LXF20B
Feb 5, 2009 07:21 PM
FuNkDrSpOt
Jan 3, 2007 10:04 PM
Markb16a
Nov 7, 2005 08:23 PM
