rubbing issues retrofitting dc integra coilovers
Old Jan 3, 2007 | 10:26 PM
benmyfriend's Avatar
Default retrofitting dc integra coilovers
hey i did search but im not exactly sure what words i should have used to do this search. anyway.
i know that if you want to use eg or dc coilovers on an ef u have to get the front forks from either of those cars.
someone told me when using the eg or dc front forks the forks will rub against the axles. does anyone have any experience with this problem and how did u fix it?
im thinking about shaving off some of the metal from the inside of the fork but i have my doubts because this may effect the structural integrity of the forks.
there is also another problem and that is maybe it wont rub for a d-series axle and will for a b-series axcle or the other way around.
thanks, any comments are appreciated
Modified by benmyfriend at 11:16 PM 1/4/2007
Old Jan 4, 2007 | 01:40 AM
bump
Old Jan 4, 2007 | 04:04 PM
Default Re: rubbing issues retrofitting dc integra coilovers (benmyfriend)
bump
Old Jan 4, 2007 | 05:06 PM
VtecSyndrome's Avatar
Unless you are talking about a sleeve coilover kit, why in the world would you try to fit the WRONG shock on the front of your REX. I keep hearing about this stupid "trick", just get the RIGHT coilovers for your rex and you won't have problems. the geometry is totally different from the EG/DC than it is w/ the EF body, even if you make it bolt up it still will not perform like the properly designed EF suspension would!?!?! I run Skunk 2 coilovers for a DC2 integra on my CRX for the added stiffness but they physically bolt up the same and match dementions with the EF setup. Fullbody DC coilovers do not belong on an EF...PERIOD! (well, the fronts anyway).
Old Jan 4, 2007 | 06:13 PM
Default Re: rubbing issues retrofitting dc integra coilovers (VtecSyndrome)
the reason some one would do this is because the selection of full coilover suspension for efs is not that great, some one might want to run a certain brand coilover that does not manufacture a kit for the ef. maybe some people want to run some thing diffeferent than g/c + koni yellows.
Old Jan 4, 2007 | 06:27 PM
thank you for you comment vtecsyndrome your opinion is appreciated
Old Jan 4, 2007 | 10:13 PM
anyone? bump
Old Jan 5, 2007 | 02:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benmyfriend &raquo;</TD></TR><TR><TD CLASS="quote">the reason some one would do this is because the selection of full coilover suspension for efs is not that great, some one might want to run a certain brand coilover that does not manufacture a kit for the ef. maybe some people want to run some thing diffeferent than g/c + koni yellows. </TD></TR></TABLE>
Tein.....need I say more?? You gotta pay for it of course but man it's an awesome setup. You get what you pay for.
Old Jan 5, 2007 | 11:17 PM
not a fan of tien either but thanks for the input. want to run dc coilovers
iheartxhonda
Oct 7, 2008 11:01 AM
itsmarcnotmark
Oct 6, 2008 07:00 AM
tegman23
Feb 24, 2008 02:38 PM
DB2NineDuece
Northwest (Sales)
Nov 12, 2007 07:33 PM
mikaleg6
May 16, 2005 12:00 AM
