any one have a step by step post of how to put an ls ina crx
you should start out doing smaller stuff first. From reading your post it sounds like you dont have much experience. It would probably be best you take it to a competent shop.
i did an ls swap on my dx and the info on this page was very useful. i do know that on the hf you need to get si or dx front discs so the axles will fit.
here's the site
http://www.nor calcrx.org/droppedcrxsi/step-by-step.htm
no space here ^
but yeah do some searching there's lots of info here
here's the site
no space here ^
You'll need DX or Si hubs,the HF's won't work......
"If your car is a CRX HF or Civic Std (4 speed) you will need Knuckle and hubs from any other model Civic or CRX except the 90-91 Civic EX. If you want to use knuckle and hubs from the 90-91 EX, you will also need the calipers, rotors and brake lines. The EX has larger brakes."
http://www.hasport.com/tech/in...t.htm
Modified by TEXREX88 at 9:12 AM 1/4/2007
Modified by TEXREX88 at 9:14 AM 1/4/2007
hondaf8
Oct 12, 2010 11:58 PM
