b18c1 into eg ecu help!
Old Jan 3, 2007 | 09:14 PM
tweak016's Avatar
Default b18c1 into eg ecu help!
I'm putting in a b18c1 into my si hatch and i've searched all over the forum and i can't seem to get a clear answer on this. how do you wire the knock sensor and tha aib sensor? Do you just get any ol wire and run it from the ecu to the sensor? also will the engine run with out these sensors plugged in?
Old Jan 3, 2007 | 09:18 PM
ekb16's Avatar
u run the wires from the sensor straight to ur ecu...find the ecu pinout ur using and pin it to the right spot...try to use the same gauge wire so u wont have alot of resistance in the wire...yes the engine will run without it but it will run bad and unsafe
Old Jan 3, 2007 | 10:04 PM
BlakeJ53's Avatar
Default Re: b18c1 into eg ecu help! (tweak016)
Try the FAQ at the top of the page there is a lot of helpful info in there!!!
Old Jan 4, 2007 | 08:22 AM
tweak016's Avatar
i looked at the sticky and i still cant seem to figure it out (maybe i'm just daft) but do i just get a wire and splice onto the ecu and the knock sensor? what is the exact method of wiring the ecu? or is there a link that can help me out? its all very unclear to me
Old Jan 4, 2007 | 10:43 AM
Relic1's Avatar
IAB wire - normal 20awg wire.
knock sensor - shielded wire (mic wire from radiocrap works good)
the engine will run without those sensors but you will get a CEL. IF you're using the P72.
Old Jan 4, 2007 | 11:44 AM
tweak016's Avatar
what should i use as far as a connector?
Old Jan 4, 2007 | 11:56 AM
Relic1's Avatar
for the IAB? simply pick up one from a junk yard or spice it directly
knock - again connector from a junk yard works the best.
bcphatchback
Dec 3, 2007 06:48 PM
stocker2shocker91
Aug 23, 2007 04:06 PM
nub_pwn
Nov 18, 2006 11:48 PM
