Will a WIDE integra radiator fit a 98 accord???
Old Jan 3, 2007 | 06:13 PM
716pro's Avatar
Default Will a WIDE integra radiator fit a 98 accord???
I need a new rad. will a integra rad fit a 98 accord 4 cyl.? Anyone know or have tried?
Old Jan 3, 2007 | 07:05 PM
hondadude's Avatar
Default Re: Will a WIDE integra radiator fit a 98 accord??? (716pro)
I'm going to guess you can get the teg rad for free?
grab up your handy dandy measuring tape and get busy!!
Also don't forget to check the little mount posts on the bottom of the rad; then the cooling fan mounts and wire harnes.
Let us know how it all measures out.
Old Jan 3, 2007 | 07:19 PM
716pro's Avatar
Default Re: Will a WIDE integra radiator fit a 98 accord??? (hondadude)
Not free but its brand new and the guy wants $30 for it. Hes not sure if it will fit, I might try and see. I will let you guys know if it does.
Old Jan 3, 2007 | 11:47 PM
TOP END MS's Avatar
Id assume NO.
Old Jan 5, 2007 | 08:28 AM
716pro's Avatar
Default Re: (TOP END MS)
It does not, I checked some side by sides online and its close but no dice.
Old Jan 5, 2007 | 02:07 PM
technine's Avatar
I put a DA integ radiator in my CD7 and it fit the lower mounting holes, but you will have to fab up the upper braces so it stays put and run a different upper hose so it will not kink and you will have to modify or buy a slim fan for it because your factory one will not fit. I discovered that one had a hole in it so I just went out and bought an accord one at Autozone for $100.
Jake_r27
Jan 28, 2014 08:37 PM
CRXBOI239
Feb 18, 2009 05:47 PM
DC4 Rasta
Feb 10, 2006 02:38 PM
b18c5cvc
Oct 24, 2003 06:20 PM
99lsvtecauto
Aug 28, 2003 11:06 PM
