my left rear bearing is bad how difficult's to replace them need Helps
I'm pretty sure the rear bearings is replaced along with the hub. Therefore just replace the entire hub assembly. And get a helms it will tell you how to do everything and will be the best investment you can ever make.
Ali
Ali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 »</TD></TR><TR><TD CLASS="quote">I'm pretty sure the rear bearings is replaced along with the hub. Therefore just replace the entire hub assembly. And get a helms it will tell you how to do everything and will be the best investment you can ever make.
Ali</TD></TR></TABLE>
thanks...i got the hub assembly...just don't know where to start....i was about to order Helm online that goes for 37 buck??
take off the rear wheel. take off the brake caliper and rotor. pop the metal center cap off. use 32mm socket to remove nut. take off old hold. put back on in reverse order. however i dont know the ft-lbs. required to torque it back on off the top of my head. and thats a simplified version. but its really just about a 45 min job to do it. i have faith in you
i needed to do this on my 94 rs and u need to take the caliper bracket off to get the rotor off carefull, the bracket bolts sometime seize so just be carefull not to strip them b/c i did to one of them, f**king pain in my ***. good luck and it really is not a hard job to do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CJ_2Dr »</TD></TR><TR><TD CLASS="quote">i needed to do this on my 94 rs and u need to take the caliper bracket off to get the rotor off carefull, the bracket bolts sometime seize so just be carefull not to strip them b/c i did to one of them, f**king pain in my ***. good luck and it really is not a hard job to do</TD></TR></TABLE>
thanks bro..i know what you're talking about..i broke one of the caliper shield cover due to rust and it's tough to get it out...boy i'm going to have funs doing this job..any more suggestions please don't hesitate ...take care.
eg:R
10
Oct 15, 2011 02:15 PM
pcorad
May 30, 2002 12:36 PM
