whay kind of axel to run in my ls swap rex ls axel is poppoing out
Old Jan 3, 2007 | 12:42 PM
delsollove's Avatar
Default whay kind of axel to run in my ls swap rex ls axel is poppoing out
hello my 90-93 ls axels are popping out of the boot when i statr to go only on the driver side thow what axel will work that is about 1inch longer
Old Jan 3, 2007 | 12:46 PM
bag's Avatar
bag
Default Re: whay kind of axel to run in my ls swap rex ls axel is poppoing out (delsollove)
get the correct halfshaft. (90 teg)
Old Jan 3, 2007 | 01:12 PM
delsollove's Avatar
Default Re: whay kind of axel to run in my ls swap rex ls axel is poppoing out (bag)
whats that the mid shaft for what car crx or teg
Old Jan 3, 2007 | 03:02 PM
bag's Avatar
bag
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsollove &raquo;</TD></TR><TR><TD CLASS="quote">whats that the mid shaft for what car crx or teg</TD></TR></TABLE>
teg..if you use the 90 integra halfshaft with the 90 integra axles there will be no problems....how you say you need an 1" longer axle doesnt sound right..sounds like you have a sir1 b16 halfshaft with a 90 integra axle..
Old Jan 3, 2007 | 04:37 PM
ivan1985's Avatar
Did you take the dust covers off?
Old Jan 3, 2007 | 04:41 PM
bag's Avatar
bag
Default Re: (ivan1985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivan1985 &raquo;</TD></TR><TR><TD CLASS="quote">Did you take the dust covers off?</TD></TR></TABLE>
that wouldnt make a difference with his problem,he says the axle is falling apart and its 1" to short..if he said it was binding i would have mentioned the dustshield..
Old Jan 3, 2007 | 04:43 PM
EatSleepJDM's Avatar
you need to match the year of the half shaft with year of the axles, i am using 90' axles and half shaft in my crx with no problems what so ever
Old Jan 3, 2007 | 04:55 PM
98lude-t's Avatar
Default Re: (EatSleepJDM)
im using 88 teg axles and 93 int shaft. they work great and they are chaeper
Old Jan 3, 2007 | 05:12 PM
delsollove's Avatar
ok ill try that ill keep tou all in formed tomarro
Old Jan 4, 2007 | 05:54 PM
delsollove's Avatar
Default Re: (delsollove)
ok i just bought this car so ive been working out problems and the problem was that the upper driver side mount was barely loose to where when you rev the car the motor dont move but when you drive it it moves like a frieght train just by taking off my hood so my buddy can paint it and went to get food i saw the motor move so i fouund out all the bolts were stripped out and JB WELDED and i had to re tap them
Old Jan 4, 2007 | 06:31 PM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsollove &raquo;</TD></TR><TR><TD CLASS="quote">ok i just bought this car so ive been working out problems and the problem was that the upper driver side mount was barely loose to where when you rev the car the motor dont move but when you drive it it moves like a frieght train just by taking off my hood so my buddy can paint it and went to get food i saw the motor move so i fouund out all the bolts were stripped out and JB WELDED and i had to re tap them </TD></TR></TABLE>Good thing nothing worse happened to the car and a rule of thumb when you buy a used car check it bumper to bumper bolt for bolt especially if it's already modded.
Mr. DeOro
10
Jun 13, 2010 05:25 AM
haroldthefly91crx
Jun 22, 2008 08:18 AM
wens_crx
Jun 1, 2007 05:57 AM
EF_ST@TUS
Jun 26, 2006 10:16 AM
KevronsEG
Dec 10, 2001 12:51 PM
