crx side moldings..
Old Jan 3, 2007 | 09:47 AM
4DRmafia's Avatar
Default crx side moldings..
is there a right way to remove the crx side moldings off a junkayrd crx and put them on my crx ? i'm scared of bending them or what not. am i suppose to slide them forward of the car? what abt the crx oem side skirt ?
Old Jan 3, 2007 | 10:45 AM
bag's Avatar
bag
Default Re: crx side moldings.. (SkipMic2006)
removing them from a car with pillar mounted seatbelts ,you can do it without breaking clips...undo the bolts that hold the front and rear part of the molding to the door,,then remove the interior door panel and you'll see the clips ,,,squeeze them on both sides to release the moldings...
wit the doors that have seatbelts built in,,just get a flathead screwdriver,and a rag,,and pry it off you'll break clips no matter what..
for the lower sideskirt remove all the screws,,(theresa lot) then pry out those black things the screws came out of with a small screwdriver,,then pull,,you'll probably brake these clips also..sorry
Old Jan 3, 2007 | 12:45 PM
4DRmafia's Avatar
clips break so easy ...damnit
crxblues
Aug 24, 2009 12:59 PM
Eaglekper0046
Apr 1, 2006 03:12 PM
gocivicgo
Jun 17, 2003 08:49 PM
