Where is the Fast Idle Thermo Valve?
Old May 13, 2002 | 08:50 PM
comptechgsr2000
Guest
Posts: n/a
Default Where is the Fast Idle Thermo Valve?
Where is the Fast Idle Thermo Valve? Is it behind the intake manifold?
Old May 13, 2002 | 09:00 PM
Reid's Avatar
Global Moderator
Default Re: Where is the Fast Idle Thermo Valve? (comptechgsr2000)
On a GSR intake manifold, it's located near the firewall on the manifold. It's visible from above.
But I must ask, out of curiousity, why did you ask in this forum?
Old May 13, 2002 | 09:05 PM
Rory Breaker's Avatar
Correction, on a GSR its directly ON the underside of the throttle body, held on by 3 10mm's.
Old May 13, 2002 | 09:06 PM
Reid's Avatar
Global Moderator
Default Re: Where is the Fast Idle Thermo Valve? (newgsrdriver)
Actually that's the exact place I'm describing. Was I not clear?
Old May 13, 2002 | 09:15 PM
Default Re: Where is the Fast Idle Thermo Valve? (Reid)
Near the firewall on the manifold is an accurate description of a part located under the throttle body, not touching the manifold in any way other than a coolant hose? News to me!
illprelude
Jul 11, 2008 05:04 AM
hectic57
Mar 19, 2008 08:16 AM
bobukler
May 29, 2006 08:50 PM
turboed4life
May 15, 2004 12:14 PM
b16hybrid2
Jun 10, 2003 05:46 AM
