My TimingBelt Snapped
Old Jan 2, 2007 | 06:18 PM
EfSedanLove's Avatar
Default My TimingBelt Snapped
i was wondering if i can put a obd0 d16a6 intake manifold, obd0 d16a6 dizzy, and the obd0 engine harness on the d16y7? will this work and is their any modifications? i was thinking if the obd0 dizzy dont fit can i cut the wires off the obd1 and put the obd0 one on it. because my d16a6 timing belt snapped just 30 mins ago, and my friend is giving me his motor. I have a 91 civic Lx w/D16a6 engine, the D16y7 is out of a 96 Civic Dx. Also my trans and clutch will fit the d16y7 since its a d series?
Modified by EfSedanLove at 9:29 PM 1/2/2007
Modified by EfSedanLove at 9:44 PM 1/2/2007
Modified by EfSedanLove at 9:45 PM 1/2/2007
Old Jan 2, 2007 | 06:43 PM
MENACE's Avatar
Default Re: My TimingBelt Snapped (EfSedanLove)
Yeah that will work. As a matter of fact the D16y motors will let you bolt the dizzy up with no problems like the Z6's have. Also youll have to remove or tie up the crank sensor wire. The Y8 and Y7 have it on the crank instead of the dizzy like the a6. Also the coolant temp sensor for the fans will have to be rewired, its not on the back of the block on the y8, its on the thermostat housing. Other than those few simple things it will be a direct fit. Good luck If you need some more help just let me know.
Old Jan 2, 2007 | 06:49 PM
Default Re: My TimingBelt Snapped (MENACE)
mybad EDIT! i believe its the D16y7 non-vtec, so i can use my d16a6 dizzy on the d16y7? nice! humm im running no fan, does it matter L0l or im not going to get a reading on my cluster for temp? i dont think it isnt that hard to rewire the temp right?
ohh im running no fan because it was a tight fit when i put the turbo in : ). Ya thats why my timing snapped --- 184xxx Miles on a d16a6, doesnt burn oil but wastes gas, never did a timing = snap, no head tick though
Old Jan 2, 2007 | 06:58 PM
MENACE's Avatar
Y7 and y8 are the same blocks, for the most part. As far as the no fan dont worry about the switch then lol. The one for the temp reading is on the side of the head, next to the heater hose connection, under the distributor. im pretty sure its the same connecter and everything.
Old Jan 2, 2007 | 06:59 PM
cool cool, i thank you for helping
Old Jan 2, 2007 | 07:03 PM
MENACE's Avatar
No problem man, just let me know if you need some more.
Old Jan 3, 2007 | 10:44 AM
also will my 91 motor mount fit the 96 motor mount which is on the timing belt side? like if i take the hole motor mount off the motor and switch them?
Old Jan 3, 2007 | 11:07 AM
goforbroke's Avatar
MEAT PATTY
Why don't you just replace the timing belt with your fingers crossed hoping you didn't bend a valve.
Old Jan 3, 2007 | 11:45 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EfSedanLove &raquo;</TD></TR><TR><TD CLASS="quote">also will my 91 motor mount fit the 96 motor mount which is on the timing belt side? like if i take the hole motor mount off the motor and switch them?</TD></TR></TABLE> Yup, switch the complete mount -- bracket + mount -- and you'll be good to go.
Old Jan 3, 2007 | 09:20 PM
Default Re: My TimingBelt Snapped (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just replace the timing belt with your fingers crossed hoping you didn't bend a valve.</TD></TR></TABLE>
lol because i allready pulled the motor and found out the valves are good Mini Me time!
also the D16y7 has 90k miles and itle also be boosted
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Yup, switch the complete mount -- bracket + mount -- and you'll be good to go.</TD></TR></TABLE>
Will do Thanks
Old Jan 3, 2007 | 10:48 PM
trompeta performance's Avatar
pardon me bro but iam from puerto rico what do you meen by a (dizzy) over here its got another name probably??
Old Jan 4, 2007 | 05:58 AM
goforbroke's Avatar
MEAT PATTY
Default Re: My TimingBelt Snapped (trompeta performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trompeta performance &raquo;</TD></TR><TR><TD CLASS="quote">pardon me bro but iam from puerto rico what do you meen by a (dizzy) over here its got another name probably??</TD></TR></TABLE>
He means distrubutor, homey.
Old Jan 6, 2007 | 09:41 PM
Default Re: My TimingBelt Snapped (goforbroke)
ok everythings bolted in and now it wont start! i have the A6 dizzy on the Y8, what are the firing order? ill post a pic of the set up
Jmar9289
14
Jan 13, 2011 10:25 AM
Mr_Moos
Mar 30, 2007 10:07 PM
dumped4dr
Jul 30, 2006 05:16 PM
Maxpower350
Jul 17, 2006 08:57 PM
ABK
May 6, 2004 07:48 AM
