need ne clutch?
Old Jan 2, 2007 | 04:25 PM
91(si)hatchey's Avatar
Default need new clutch?
alright my friend says i need a new clutch because sometime it doesn't go into reverse. and lately my car has been like having trouble accellerating like it boggs at 3k rpm. what could be the problem and if its my clutch what kind of clutch would be best for the next month or two and then when i swap in my rebuilt h23 head.
Old Jan 4, 2007 | 12:58 AM
TOP END MS's Avatar
ya sounds like a slipping clutch. Chances are the pad on the disc is worn down and non friction material is mating to the flywheel or pressure plate causing loss of grip. If I was you I would try to get a JUN flywheel. it is 1-peice Chromoly. about 12lbs, and very strong. Because it is one peice .. you do not have to worry about the complications of the aluminumplate-inside-steelring issues. (they heat and expand at different temperatures).
I think it cost around $350 which is not bad at all.
Old Jan 5, 2007 | 12:32 PM
FarinaMotorsports's Avatar
Default Re: (TOP END MS)
If it doesn't want to go into reverse it could be the trans itself or the linkage and not the clutch. Also is it bogging at 3k rpm or slipping? If it's bogging that's not a clutch problem it's a problem somewhere else.
Old Jan 6, 2007 | 09:34 PM
Default Re: (FarinaMotorsports)
ya the clutch slippage and bogging are two different question, im guna run fuel injection cleaner thru my car net week also ill check my clutch reservoir on monday. so would getting a new fly wheel help my clutch or should i get a new clutch like act or clutch masters.
SpOoNisMyFriEnD
May 11, 2005 02:18 PM
Chiller
Apr 10, 2005 10:52 PM
Nextelbuddy
Mar 5, 2004 06:06 PM
abeaujuin
Jan 9, 2004 04:43 AM
uszcrx
Jun 30, 2003 09:04 AM
