89 Civic DX Cutoff Problem
Old Jan 2, 2007 | 04:15 PM
tecmand's Avatar
Default 89 Civic DX Cutoff Problem
I have a 1989 Civic Dx. It started a new problem today. When I crank the car up, it actually starts, runs for about 1-2 seconds, and cuts off. Restarting the vehicle results in the same symptoms. On about the 4-5 start, the engine will stay running. This occurred several times today. When I left work, the same issue occurred, only the check engine light came on. I checked the ECM for error codes, and the only error code it displays is error code "1". This says oxygen sensor, but I replaced it earlier this summer. Also, the ECM always shows this error code, so this is not new. Anyone have any suggestions? Also, FYI, I replaced the Main relay this summer. Thanks in advance.
Old Jan 2, 2007 | 06:10 PM
boosted crx-r's Avatar
Default Re: 89 Civic DX Cutoff Problem (tecmand)
my ignition switch went bad and started to do the same thing....would even cut off on me when i was driving down the street. I replaced the white piece on the back of the switch and haven't had any problems with it in 2 years. Also my fuel pump started going bad and did the same thing.
rfazio
Feb 13, 2012 09:43 AM
dookeye
12
Oct 24, 2009 06:16 PM
bobdlee
Dec 18, 2008 01:15 PM
lilhatch89
Nov 16, 2007 01:15 PM
bmow
Dec 11, 2006 06:01 PM
