hey i need help ASAP
Old Jan 2, 2007 | 03:28 PM
bigluelok's Avatar
Default hey i need help ASAP
well i just got my ls block and head from the machine shop and i need a step by step guide on putting it back together so can any one help me out please i need to get the car done or i have to get rid of it
Old Jan 2, 2007 | 07:07 PM
mahatma's Avatar
Default Re: hey i need help ASAP (bigluelok)
buy an integra manual....it will walk you through every step. only $20 or so
Old Jan 2, 2007 | 07:11 PM
nihad's Avatar
put the pistons and rods to gether. Put the rings on the pistons and the bering in the block and thighten it down gasket and mount the oil pan on turn the engine over and put the head gasket on and tighten the head down use ing head bolts.gasket and bount the valve cover. not sure about the psi on the bolts ask some one or honda dealer.
Old Jan 2, 2007 | 07:14 PM
mahatma's Avatar
Default Re: hey i need help ASAP (nihad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad &raquo;</TD></TR><TR><TD CLASS="quote">put the pistons and rods to gether. Put the rings on the pistons and the bering in the block and thighten it down gasket and mount the oil pan on turn the engine over and put the head gasket on and tighten the head down use ing head bolts.gasket and bount the valve cover. not sure about the psi on the bolts ask some one or honda dealer. </TD></TR></TABLE>
yeah on 2nd thought forget the manual. just do ^this^
Old Jan 2, 2007 | 07:50 PM
Suck my DX's Avatar
Default Re: hey i need help ASAP (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">
yeah on 2nd thought forget the manual. just do ^this^ </TD></TR></TABLE>
ROFLMAO
the helms manual is your best bet if you plan on tackling this yourself....not too hard for a first timer if you take your time and triple check everything...
however putting a motor together isnt as simple as tightening a few bolts...there are certain tools you need to take measurments and check clearances...the helms manual will cover everything and if you need more help we can hook you up online
Old Jan 2, 2007 | 08:18 PM
RCautoworks's Avatar
Default Re: hey i need help ASAP (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">
however putting a motor together isnt as simple as tightening a few bolts...there are certain tools you need to take measurments and check clearances...the helms manual will cover everything and if you need more help we can hook you up online</TD></TR></TABLE>
Yep
NegativeXero
Jan 6, 2008 03:48 PM
TJ500
Jul 10, 2007 11:25 AM
DB2#308
May 17, 2004 11:54 PM
AznBlueBoy
Apr 1, 2004 05:44 PM
D1ANCER
Mar 20, 2002 07:12 PM
