JDM CRX SIR Front Bumper w/USDM Bumper Support (MORE ??'s INSIDE)
Can I cut the parts of the usdm support and or bumper to make it fit? Or just the jdm support works?
Also What is needed to wire up the headligths the plugs are completely different I have searched but have not found enough info.
And Can someone quickly clear up the t-bar issue I know this has been covered but i have not found a straight forward answer. EF8 bar garbage? and trim and shim the usdm one to make it work??
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amthompson »</TD></TR><TR><TD CLASS="quote">pretty sure ef7 radiator support is the ticket. </TD></TR></TABLE>Yup and yes if you use the usdm bumper support you will have to cut some parts but it will work and you will probably get better fitment.
i have usdm bumper support, no cutting involved, although you do have to slightly bend it.
as far as t-bar goes, I have had no difference between usdm and jdm.
headlights:
cut off your old plugs, take the 2 (i think) yellow wires, and match them to the new plug (if the new ones have a lil bit of wire left that is) and just use 1 ground,, you dont need the other anymore
headlights:
Circuit Star-29
Apr 24, 2007 08:32 AM
payneth
Oct 14, 2004 10:16 AM
hionvtecxda6
Feb 2, 2004 08:01 AM
