ECU TUNING QUESTION
Old Jan 2, 2007 | 02:37 PM
JcAst99's Avatar
Default ECU TUNING QUESTION
WHats up, i just got my 99 gsr rebuilt after a hydrolock. The mechanics supposedly put in new gsr block, 2 layer headgasket, milled the head .020 and put in type r cams... Also added was blox IM, 65mm TB, and 3"SRI. I got full exhaust.
Now my question is this place is tellin me i dont have to tune it and this dosent make sense to me... I figure ii needed a p28 and s100 to accomidate for the single stage IM and raise vtec??????
Old Jan 2, 2007 | 02:45 PM
lVlemphizStylez's Avatar
Default Re: ECU TUNING QUESTION (JcAst99)
you should definately tune the car....
Old Jan 2, 2007 | 02:46 PM
JcAst99's Avatar
Default Re: ECU TUNING QUESTION (lVlemphizStylez)
wont it run all out of wack with these mods and no tuning? It startin to seem this place is feedin me a crock of ****, i seen the block before it went in and looked nowehere near new... I never heard of just slappin in cams and all these parts on a obd2 ecu w/ no tuning... I have no way of knowing if they actually did the work they did, I need some help and dont wanna get ripped off, thanks
Old Jan 2, 2007 | 03:01 PM
tweekerz's Avatar
The mod that requires tuning here is the TB & IM combo. That'll probably mess with your air fuel big time. Anyway, get those mods working together and im sure you'll get even more power.
Old Jan 2, 2007 | 03:14 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
As ^ said, the TB and IM changes things a bit but I wouldnt say the tuning is necessary. Now, that doesnt mean that a chip reprogram isnt a good idea. Your ecu isnt taking full advantage of your mods, so yeah a uberdata or crome upgrade would be nice. But again, it's not necessary. Your car just wont full use the upgrade their their utmost potential.
As for the block being new, I doubt that. No shop I know would use a brand spanking new, fresh from the Honda dealer block. Did the specify it the block was going to be new as in fully rebuilt with new gaskets/bearings/rings?
And if you want to make sure they actually installed ITR cams shafts, there is a way to tell by looking at the grooves on the cams. Do a quick search and you find a how to with pictures. Then just pull off your valve cover and compare your cams with the pics.
Old Jan 2, 2007 | 03:17 PM
Default Re: ECU TUNING QUESTION (CARMA_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CARMA_626 &raquo;</TD></TR><TR><TD CLASS="quote">As ^ said, the TB and IM changes things a bit but I wouldnt say the tuning is necessary. Now, that doesnt mean that a chip reprogram isnt a good idea. Your ecu isnt taking full advantage of your mods, so yeah a uberdata or crome upgrade would be nice. But again, it's not necessary.
if you want your car to run like **** and bog at vtec crossover with ITR cams...then yea skip tuning...car wont blow up, but dont expect to enjoy it
Old Jan 2, 2007 | 03:32 PM
JcAst99's Avatar
exactly, thats what makin me doubt they even put in the cams if they werent planning on tuning.
jdm_h22
Engine Management and Tuning
26
May 30, 2011 06:25 PM
just_bn_me83
Jan 6, 2011 04:24 PM
fv8s
10
Feb 14, 2010 04:47 PM
97_gsr
Jul 14, 2007 08:45 AM
97_gsr
Jul 13, 2007 11:14 AM
