Honda Fit Honda Fit (Jazz)
My Fit wouldn't start!!
Old Jan 2, 2007 | 12:38 PM
Bonedoc's Avatar
Default My Fit wouldn't start!!
Howdy all you Fit freaks .
I've Had my Fit since april, and have thoroughly enjoyed it. However, to my dismay, it wouldn't start this morning. I'm sure it's not a dead battery issue as I've tried jumping it. Besides, when I turn the key, the power would cut out to the peripherals, but no response, not even a cough-like response you'll get when a car with low battery tries to start. What could be the problem?
I figure, the only thing that is different is that the EPS (steering) light was on.
Any ideas are greatly appreciated.
Old Jan 2, 2007 | 02:26 PM
Milano Sol's Avatar
Default Re: My Fit wouldn't start!! (Bonedoc)
the EPS light should come on in the accesory position anyways.....if youve already tried jumping it and still no start all i can say is take it back to the dealer.
is this a manual or auto? if its a manual you can try push starting it.....
Old Jan 2, 2007 | 03:04 PM
dai's Avatar
dai
Sounds like it's the immobilizer kicking in
Old Jan 2, 2007 | 03:20 PM
jetydosa's Avatar
25 Year Member
Default Re: (dai)
Push in the clutch...
Old Jan 2, 2007 | 03:35 PM
PogKai's Avatar
Default Re: (dai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dai &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like it's the immobilizer kicking in</TD></TR></TABLE>
then the green key on the cluster should be blinking non-stop.. checked that?
Old Jan 2, 2007 | 05:33 PM
koolkevin1107's Avatar
Default Re: (PogKai)
you know what. i had the same problem. it is the DBW fuse blew. cuz i accidentally pulled that out thinking it was an extra fuse and the car wouldnt start. try checking ur fuse box. also, try checking the ignition coil fuses. they should be right next 2 each other (blue 15amp if i remember correctly)
Old Jan 2, 2007 | 08:37 PM
Bonedoc's Avatar
I was able to push start it by rolling it down the hill and engaging it in 2nd gear. But the starter makes no effort to even crank. So I brought it to the dealer late today, and the guy said that it might be the relay... I'll keep you guys posted.
btw, once the car runs, none of the lights come on.
Old Jan 6, 2007 | 07:57 AM
over_'s Avatar
well?? what happened?
Old Jan 8, 2007 | 05:35 PM
Bonedoc's Avatar
You wouldn't believe it, but the after market carpet mat (I had one of those thick rubber ones to contain mud and spillage) got under the clutch enough to prevent it from arming the starting system.
I was able to start my car by rolling it down the hill (where I live) and engaging it in 2nd gear.
Well, I don't feel too bad about it because it took the Honda tech a whole day to figure that one out also
Old Jan 8, 2007 | 11:44 PM
ricecooker415's Avatar
wow
Old Jan 9, 2007 | 04:58 AM
towelie's Avatar
Default Re: (koolkevin1107)
thats werid check ur fuses man
Old Jan 10, 2007 | 05:48 AM
1dumbscreenname's Avatar
Default Re: (towelie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by towelie &raquo;</TD></TR><TR><TD CLASS="quote">thats werid check ur fuses man </TD></TR></TABLE>
he already updated look up ^
Nice Fit
Honda Fit
19
Jan 4, 2020 03:23 PM
T0mas
Honda Fit
Jul 27, 2018 10:43 AM
alexdbest
Honda CR-V & Element
12
Dec 23, 2013 03:55 PM
brad86
May 30, 2004 02:37 PM
95integrags-r
Nov 17, 2003 11:33 PM
