JDM FRONT END
Old Jan 2, 2007 | 10:36 AM
fbpem1's Avatar
Default JDM FRONT END
i installed the front end but my car has the abs the blocks the hid housing for the headlight...what can i do to resolve this situation?
Old Jan 2, 2007 | 10:51 AM
PrinceAli132's Avatar
Default Re: JDM FRONT END (fbpem1)
Switch to a 98+ abs system.
Or maybe you can find a way to extend the wires for the hid ballasts or whatever that thing is that is coming in the way.
Remove ABS.
Ali
Old Jan 2, 2007 | 10:56 AM
DjMigs's Avatar
im sure those who know will chime in....
im assuming you have a 94-97 gsr if so i believe you either have to remove your abs unit or remove it and upgradeto 98+ but i dont know much about that (i dont think its a simple R&R) or if i remeber i think the ballast is on top of the back housing if so see if its removeable to install housing if so then you have to mount the ballast else where but withing its reach...
im planing the same setup but when i get it i figure it out then...
orion840
Oct 23, 2007 01:39 PM
maxboost_50psi
Aug 19, 2006 10:05 AM
SiRTifiedacc
Dec 15, 2005 12:14 AM
DC2 to AP2
Mar 23, 2004 07:36 AM
