crx ecu
Old Jan 2, 2007 | 10:28 AM
crxricer66's Avatar
Default crx ecu
is the light on the ecu supposed to turn on real quick and then right off. it is an 88 crx hf, also someone said there is a fuse for the fuel pump in the engine compartement on the right side?? i cant find it maybe sum1 knows. thx
Old Jan 2, 2007 | 10:34 AM
89efDUSTY's Avatar
Default Re: crx ecu (crxricer66)
stay with the same post dont make new ones just be patient and someone will help...
Old Jan 2, 2007 | 10:40 AM
crxricer66's Avatar
Default Re: crx ecu (89efDUSTY)
ok do u no about the light?? thx
Old Jan 2, 2007 | 12:00 PM
gsxr1k05's Avatar
the fuse for the fuel pump is under the hood on my 90 crx dx. i would assume that it is in the same place. you fuse box should be located under the hood on the passenger side. as for the ecu light, yes that is normal.
eatxsleepxjdmx
11
Aug 14, 2012 06:12 PM
Graemes_Rex
Feb 2, 2012 05:02 PM
crxricer66
Jan 2, 2007 12:58 PM
91highryda
Dec 31, 2006 02:27 AM
red civic standard
Aug 9, 2006 03:50 PM
