Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Suspension of the 03-05 hybrids?
Old Jan 2, 2007 | 08:34 AM
efficiencyJunkie's Avatar
Default Suspension of the 03-05 hybrids?
Hey guys, random question -
Do you guys know if the supension on the hybrid is similar, or the same as the standard civics?
I dont want to buy one and slam it, but probably just change the shocks and buy some Koni yellows.
Anyone familar with them at all?
thanks!
Old Jan 2, 2007 | 09:21 AM
Boilermaker1's Avatar
The layout is the same... but the rear springs are going to be rated to hold up the batteries as well. Using standard sedan springs is going to give it a saggy ***, but using only koni yellows should be fine.
Old Jan 2, 2007 | 10:09 AM
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">The layout is the same... but the rear springs are going to be rated to hold up the batteries as well. Using standard sedan springs is going to give it a saggy ***, but using only koni yellows should be fine.</TD></TR></TABLE>
Good point man.
I dont feel like experimenting with spring rates to compensate for the extra 100 pounds in the back - if I went with a coilover setup anyways. (no matter how much i want to......haha)
Modified by carbnjunkie at 11:30 AM 1/2/2007
boogie37
Suspension & Brakes
19
Oct 17, 2005 08:46 AM
TypeR1558
Mar 24, 2004 07:47 PM
i
Mar 7, 2004 09:40 AM
Creep
Jan 5, 2004 11:21 AM
grlstockb18c1
May 15, 2003 03:52 PM
