need help with b16a won't start
non ef distributers use different ohms, do a spark test, i dont know if 90-91 tegs are different but i know you cant use gsr dist. out of that style teg
im going to do the same swap in about a month or so fromnow, and i heard of distributor problems er somemthing for the B16A (SIR I), jus to make sure, is this really somthin i have to worry about before i do the swap? if so, what can i do to avoid it?
the swap is easy it's just the distributor that's the hard part my motor was running fine until the dis went and i can't find the original non obd dis so i'm tring a 90-91 ls one but still working out the problem+
the only difference between the b16a dist and an Ls is one mounting leg.
jedubz
Jul 15, 2005 08:46 AM
