4 door integra owneres, trunk is leaking, anybody else have this problem?
Does anybody else have this problem, my trunk has been leaking, i think i need to just replace all the rubber seals back there, but it has even gotten to the point where when it is super wet outside it leaks into the bottom of my back seat, so it is leaking bad.... any ideas??
A common cause of trunk leaks in three-door Integras is when there is a crack in the taillight assembly (often you can see moisture inside). The water leaks in and goes to the lowest point, flooding around the spare tire. I assume that's a possibility in four-doors, too (but it sounds like your leak may be different).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len »</TD></TR><TR><TD CLASS="quote">Check the weather stripping on the trunk lid and the seal on the back window.</TD></TR></TABLE>
how much does new weather stripping cost for this Len?
Do you have a sunroof?
Remove the rear plasitics and check the drain tubes. Sometimes they come loose and leave water in the trunk area.
http://www.team-integra.net/se...D=546
http://www.team-integra.net/se...=1021
Ali
Ali
92EGMINIME
Apr 8, 2009 12:34 AM
