need help in removing exhaust
Old Jan 2, 2007 | 04:48 AM
661rex89si's Avatar
Default need help in removing exhaust
ok well here is a bone head question
im trying to remove my custom exhaust cuz im trading it for something else need something bigger anyway. well its welded all together so im trying to find out the best way to remove it without cuting it. if it aint possible then ill just take it to get removed.
Old Jan 2, 2007 | 04:59 AM
CRX Toad's Avatar
Default Re: need help in removing exhaust (661rex89si)
If it is all welded it will have to be cut. Unless you take it off with the header and all.
Old Jan 2, 2007 | 07:44 AM
gsxr1k05's Avatar
Default Re: need help in removing exhaust (CRX Toad)
word.
Old Jan 2, 2007 | 07:47 AM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">If it is all welded it will have to be cut. Unless you take it off with the header and all. </TD></TR></TABLE>
Or unless you have access to a lift because it will have to be maneuvered many different ways.
Old Jan 2, 2007 | 07:50 AM
goosane's Avatar
it's welded to the cat? ? ?
Old Jan 2, 2007 | 04:54 PM
661rex89si's Avatar
no its not welded to the cat at all. the problem is i have nobody to hook me up with a sawzall or something to cut it.
Old Jan 2, 2007 | 05:02 PM
Rex89's Avatar
Default Re: (661rex89si)
unbolt it from the cat back a pic would be nice that way we could have a better view
Old Jan 2, 2007 | 05:04 PM
661rex89si's Avatar
well its just a custom exhaust that is welded together and has a oval type muffler. its just the only problem is getting it out threw the rear lower control arm.
Old Jan 2, 2007 | 06:12 PM
Got_soy's Avatar
drop the lca and swaybar.
or
cut it, it doesnt take long with a hacksaw
Old Jan 2, 2007 | 06:13 PM
661rex89si's Avatar
thanks buddy thanks for your help guys also
redGSRguy
Dec 20, 2006 03:49 PM
midwestR
Aug 17, 2006 11:39 PM
atmosphere
Aug 8, 2005 12:18 PM
nEoMuGen
Jul 28, 2004 11:50 AM
rizen
Sep 17, 2003 05:29 AM
