d15b in 89 ef
Old Jan 2, 2007 | 12:13 AM
slipperyduck's Avatar
Default d15b in 89 ef
im in the process of putting the d15b in the hatch and i have a couple of questions....
1. i have an 95 harness (vx i think) cant remember but it is vtec ready and i have a p06 ecu the real question is is it plug and play.
can i rip out the std harness and install that one and rewire the cluster.
and 2. any info or links anyone have that is useful for me
thanks
Old Jan 2, 2007 | 10:53 AM
Default Re: d15b in 89 ef (slipperyduck)
bump anyone?
Old Jan 2, 2007 | 11:25 AM
98lude-t's Avatar
word as long as ur car is an si or hf crx/civic if not well have fun wireing. there is alot of info on here about wireing search. dont use the vx harness.
Old Jan 2, 2007 | 11:54 AM
Default Re: d15b in 89 ef (98lude-t)
just found out its a dx harness guy really didnt know what he had. i have the si harness and all but the chassis is a std. will it be easier to wire if i used the si harness.
thaks
Old Jan 2, 2007 | 12:05 PM
mengy007's Avatar
If you already have the si harness on the car and working then you'll have to either buy some obd0->obd1 conversion harnesses or do the wiring yourself. If you still have the dx harness on your case then you'll have to look into doing mpfi conversion first.
Old Jan 3, 2007 | 10:39 AM
Default Re: d15b in 89 ef (mengy007)
the 95 dx harness wont work with the motor
Old Jan 3, 2007 | 05:01 PM
bump
Old Jan 3, 2007 | 09:09 PM
mengy007's Avatar
the 95 harness won't plug up to your sub harness
best way is to get jumper harnesses for OBD0 -> ODB1 for the dizzy and ECU you can always go back that way. rywire sells some
Old Jan 3, 2007 | 09:45 PM
95 harness will not plug and play
90-91 Si harness will not plug and play
You will need to use your original harness and add the additional wires in order to run the engine. You will need a obd 0-obd 1 conversion harness, p28 ecu, TD-42U distributor, 4 wire 02 sensor and resistor box.
Old Jan 9, 2007 | 10:49 PM
Default Re: (vega_box)
i have a p08 ecu right now and i am tring to find the correct pinout for it. so i can wire up my conversion harness. i pulled apart an old 89 std ecu and pulled the plus out to solder. i think i got it but making sure.
Old Jan 10, 2007 | 06:24 AM
sohcvtec91hatch's Avatar
Default Re: (slipperyduck)
I bought my harness through boomslang fabrications. It is a OBD0 to OBD1 with DPFI to MPFI. The only thing you need is a 4 wire o2 sensor. Saved me tons of hassle in my opinion.
Old Jan 11, 2007 | 06:16 PM
Default Re: (sohcvtec91hatch)
i got a few questions.
1. i used the si engine harness and kept the std harness in th e chassis. will this work correctly or not.
2. i made my own conversion harness and all the wires doesnt have a space.
3. i have the p08 ecu and i was told that a 1 wire o2 will work.
and does anybody have some good wiring schematic for the 89 and the d15b where i can wire it myself
Old Jan 11, 2007 | 07:21 PM
1 more thing is the pinout for a p28 the same as a p08 and if not u got the link for it
Old Jan 12, 2007 | 10:02 AM
bump
Old Jan 12, 2007 | 05:41 PM
bumpy
BlendedEM1
Feb 13, 2011 07:06 PM
aznboi_2
May 13, 2009 01:15 PM
ZAKU
Nov 18, 2008 04:15 PM
shackler
Mar 22, 2007 07:21 PM
HondaHeddie
27
Oct 6, 2006 07:57 PM
