1991 EF with LS swap
Old Jan 1, 2007 | 10:39 PM
isaygo's Avatar
Default 1991 EF with LS swap
ok ive got an EF with and LS swap and im having a problem. when i go to drive it its fine as long as i dont floor it . but once i do floor it it will studer then i have a ridiculous amount of power im thinking its saturated injector but i want some advice before i start taking them out.
Old Jan 1, 2007 | 10:54 PM
HaitianEF9's Avatar
Default Re: 1991 EF with LS swap (isaygo)
did u check the fuel filter becuase i kno sumone that had the same problem
Old Jan 1, 2007 | 11:11 PM
isaygo's Avatar
Default Re: 1991 EF with LS swap (HaitianEF9)
na ima going to have to check that tommorow thnx
Old Jan 2, 2007 | 03:02 AM
low91rex's Avatar
Check your plugs too. mine did that, when I got on it would break up and then a burst of power, almost like vtec only way stronger. turned out I had some nasty plugs and corroded wires. replaced those and now it runs like a champ!
Old Jan 2, 2007 | 11:04 AM
isaygo's Avatar
Default Re: 1991 EF with LS swap (next21)
butt if it was plugs it would have a messed up idle wouldnt it
Old Jan 2, 2007 | 12:16 PM
ludesrv's Avatar
Sounds like bad timing. You might have it a little to retarded and it boggs down low. I did that to mine to get it to stop idling crappy, but it didn't work out so I retimed it and it didn't have that bog.
Old Jan 2, 2007 | 03:29 PM
isaygo's Avatar
Default Re: (ludesrv)
butt its idle is fine
Old Jan 9, 2007 | 01:05 PM
blkrex's Avatar
it could b that ur plug wires have a brake in them and 1 or more are grounding 2 the block...ive had that happen 2 me twice...
broke88rex
Nov 13, 2013 09:16 PM
SiR-EJ1
Mar 3, 2008 12:46 AM
JAYDEEM95
Mar 18, 2007 09:52 PM
supracrx
Oct 29, 2006 09:58 PM
88 civic ef
Jun 15, 2005 03:00 AM
