Integra shifter Console into EF hatch
Old Jan 1, 2007 | 07:22 PM
aalb1's Avatar
Default Integra shifter Console into EF hatch
Quick question... Do I need the integra ashtray and cigarette lighter from a 94-01 integra to make the shifter/cup holder console fit? Or can I use the EF one?
Old Jan 1, 2007 | 07:29 PM
chitown_ef9si's Avatar
Default Re: Integra shifter Console into EF hatch (aalb1)
the cigarette lighter and ashtray are on the same part as the shifter/cupholder so no you cannot use the civic one.
Old Jan 1, 2007 | 07:38 PM
jdmpnoy89's Avatar
Default Re: Integra shifter Console into EF hatch (chitown_ef9si)
you dont need to use the integra cig lighter and ashtray to fit it in place..like me i bought one without it and just used a plate to cover up the area..but u cant use the stock ef one tho...heres my setup..thinkin of putting gauges in the space
Old Jan 1, 2007 | 07:41 PM
aalb1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitown_ef9si &raquo;</TD></TR><TR><TD CLASS="quote">the cigarette lighter and ashtray are on the same part as the shifter/cupholder so no you cannot use the civic one.</TD></TR></TABLE>
Are you sure they're the same part?
Old Jan 1, 2007 | 07:48 PM
CBEengineering's Avatar
any write ups on how to do this or does it bolt right up??
Old Jan 1, 2007 | 08:20 PM
problem_si's Avatar
Default Re: Integra shifter Console into EF hatch (CBEengineering)
The screw hole on the left side (under the glovebox) lines up perfectly. The one on the right side does not. I just drilled a pilot hole for the screw on that side, and its not very noticeable. For the most part, the seats kind of hold the whole thing in place pretty good.
When I do this on my new Si, I'm going to fab up some brackets to make it a little more solid under the armrest.
Old Jan 1, 2007 | 08:42 PM
Default Re: Integra shifter Console into EF hatch (problem_si)
thanks
Old Jan 1, 2007 | 11:50 PM
jpciii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBEengineering &raquo;</TD></TR><TR><TD CLASS="quote">any write ups on how to do this or does it bolt right up??</TD></TR></TABLE>
http://www.4gcivic.net/wp/integraconsole.html
Old Jan 2, 2007 | 06:26 AM
Default Re: Integra shifter Console into EF hatch (jpciii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpciii &raquo;</TD></TR><TR><TD CLASS="quote">
**** thanks
Old Jan 2, 2007 | 08:57 AM
YZFR6's Avatar
Default Re: Integra shifter Console into EF hatch (jdmpnoy89)
Dang that looks clean!
quirarte626
Nov 11, 2009 07:58 PM
DumpdEJ6
Oct 12, 2009 10:40 AM
patrickstar
Mar 24, 2009 09:47 PM
DB8
May 11, 2004 05:56 AM
EF'n Fast
Mar 17, 2002 05:44 PM
