Clutch line fittings - union, junction?
Old Jan 1, 2007 | 06:13 PM
93civic2005's Avatar
Default Clutch line fittings - union, junction?
I'm looking for a way to connect to clutch lines that each have a fitting on already. (Trying to bypass the rubber section of the clutch line) I guess I need some sort of "union" or "junction" for clutch/brake lines, but I don't know exactly what it is or what it's called or where to get it. Is that gray T-shaped thing (great description, eh?) in the upper-right portion of this picture something like what I'm looking for?
I figure I need a female-female adapter since both lines have flare nuts on their ends. Any help would be appreciated.
Old Jan 1, 2007 | 06:16 PM
schardbody's Avatar
any hardware store should have exactly what you need. just take the line or hose in with you and match it up.
Old Jan 1, 2007 | 06:19 PM
trrbl1bmx's Avatar
Default Re: (schardbody)
^^^ Lee speaks the truth ^^^
Old Jan 1, 2007 | 06:24 PM
Default Re: (p00n)
I dono, I had a bad experience with the last Autozone that I went to for flare nuts. Think they'll have the junction/union thing? (What's it called???) I might have to find a real hardware store around here...
Old Jan 1, 2007 | 06:26 PM
schardbody's Avatar
Default Re: (93civic2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93civic2005 &raquo;</TD></TR><TR><TD CLASS="quote">I dono, I had a bad experience with the last Autozone that I went to for flare nuts. Think they'll have the junction/union thing? (What's it called???) I might have to find a real hardware store around here...</TD></TR></TABLE>
thats why i didnt say PARTS SUPPLIER, i said hardware store, them people are freaks, they can look at most fittings and know the exact specs. parts stores hire wannabe gearheads that think just because they know what an alternator belt is they are a mechanic. use them for parts, nothing else.
Old Jan 1, 2007 | 06:41 PM
lol schardbody I guess that's true. Note to self: Figure out where all the hardware stores are...
Old Jan 1, 2007 | 09:31 PM
chrisw85's Avatar
Default Re: Clutch line fittings - union, junction? (93civic2005)
http://www.slhondaparts.com/br...=true
part #10 if all else fails.
Old Jan 2, 2007 | 02:21 AM
schardbody's Avatar
Default Re: Clutch line fittings - union, junction? (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.slhondaparts.com/br...=true
part #10 if all else fails.</TD></TR></TABLE>
yep.
Old Jan 2, 2007 | 07:09 AM
Default Re: Clutch line fittings - union, junction? (schardbody)
Yeh that pretty much looks like what I'd want. Some sort of junction and it can be pinned down. Excellent.
Old Jan 2, 2007 | 07:26 AM
5cottwardTM's Avatar
most likely any autoparts store could help you with that.
it seems like a junction but check to make sure.
Old Jan 8, 2007 | 08:24 AM
jdmsiR20's Avatar
Default Re: Clutch line fittings - union, junction? (EjSex_)
how about going with a full stainless steel line? i know you already found what you're looking for, but its an option...
https://honda-tech.com/zerothread?id=1545386
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude &raquo;</TD></TR><TR><TD CLASS="quote">
Freedo_Civegra
Acura TSX
Feb 18, 2018 06:53 PM
t3to4e
Jun 29, 2006 03:14 AM
Pure Sol
Feb 15, 2005 03:13 PM
integrasi
Aug 26, 2004 09:29 AM
KillaB-
Aug 22, 2004 08:13 AM
