Will 97 Civic Coupe Seats fit in a 94 Civic Coupe?
Old Jan 1, 2007 | 12:51 PM
marxx's Avatar
Default Will 97 Civic Coupe Seats fit in a 94 Civic Coupe?
Whats up everyone, i'm new to the board and had a question on seat swapping. Will front seats out of a 97 Civic coupe fit in my 94 Civic coupe? I have a chance to buy a complete clean set of 97 seats for cheap and would like to swap my current seats as they are pretty trashed. I heard they would fit, that i would just have to swap the seat tracks but thought i'd ask you guys first, thanks. Oh also will the rear seat fit also, thanks....
Old Jan 1, 2007 | 01:50 PM
sniggler316's Avatar
Default Re: Will 97 Civic Coupe Seats fit in a 94 Civic Coupe? (marxx)
You can probably make them fit, but why would you want to? My 97 seats are the most uncomfortable pieces of **** I have ever sat in! I dunno maybe 94s are worse?
Old Jan 1, 2007 | 02:14 PM
marxx's Avatar
Default Re: Will 97 Civic Coupe Seats fit in a 94 Civic Coupe? (sniggler316)
94 seats are pretty uncomfotable too, actually I think the 97 seats have more cushion....
Old Jan 1, 2007 | 03:36 PM
D1SKOOLBUS's Avatar
If you install them with the ek brackets they will only line up with 3 bolts. but i think you "might" be able to switch the rail off the eg onto the ek seat but im not positive hoep this helps a little.
Old Jan 1, 2007 | 05:29 PM
marxx's Avatar
Default Re: Will 97 Civic Coupe Seats fit in a 94 Civic Coupe? (D1SKOOLBUS)
Anyone else ever do this swap??
Old Jan 1, 2007 | 08:18 PM
robble36's Avatar
yep i had del sol seats with EK rails from my 98 EK and i switched seats with my friend's 93 EG he had GSR seats on those and all we did was explode the seats and changed out the rail that was closer to the center console on both sides ... it is a pain in the *** but just be patient it all works out all you need to do is change out the rail not the whole side becareful hope it helped
Old Jan 2, 2007 | 08:44 AM
Chim Chim's Avatar
Default Re: Will 97 Civic Coupe Seats fit in a 94 Civic Coupe? (robble36)
I've done it before using EK seats in an EF and EG as well as EG seats in an EF... It's as easy as swapping sliders for the chassis they're going into... If you choose to use the EK sliders in you EG it will take a bit massaging to get all 4 bolt holes to line up. And in the end, the seat won't slide smoothly if you ever needed to adjust it...
So the choice is yours...
Old Jan 2, 2007 | 09:10 AM
cybergreencivic's Avatar
since no one mentioned it, if you do the swap, you will sit quite a bit higher. so if your tall, (im 6'0) it kinda suxs with these seats in a 5th gen.
Old Jan 2, 2007 | 09:12 AM
perseverance's Avatar
i've got 00 si seats in mine.. they're comfy but i'm probably gonna get some integra seats again
Old Jan 2, 2007 | 09:26 AM
Default Re: (perseverance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">i've got 00 si seats in mine.. they're comfy but i'm probably gonna get some integra seats again</TD></TR></TABLE>
That's what id recoment. Bolt right in, hold you in more, and you dont sit so high.
HKN's Avatar
HKN
YES .... THEY DO FIT
miamihonda
Apr 30, 2012 07:04 AM
94_Teggy
Dec 6, 2009 04:41 PM
joshii_honda
Jul 21, 2008 12:25 AM
rugimpy
Dec 26, 2007 10:25 AM
homeskillet
Nov 28, 2004 09:57 PM
