clutch dilema
Old Jan 1, 2007 | 11:03 AM
ih8sndq's Avatar
Default clutch dilema
My b16 crx recently broke down with something messed up in the transmission. The transmission itself is not messed up, but it's either a clutch spring or a bearing that went down. Well my question is, it it was a clutch spring, could I just get a new disc, and how would I tell if the pressure plate is still good? Oh, as of right now there is a ACT 6-puck in it. Thanks in advance for the help.
Old Jan 1, 2007 | 04:19 PM
abnaasefmb's Avatar
Default Re: clutch dilema (ih8sndq)
The smart thing to do is always resurface the flywheel and put a new clutch and pressure plate in. Clean all the parts with brake cleaner before reassembling. Can you cheap out? Yes it depends on how much power you plan on holding. The question is if your clutch slips do you really mind pulling the engine and redoing everything? When it comes to clutches you really get what you pay for.
BigAnteg
May 24, 2010 01:25 PM
ih8sndq
Jan 2, 2007 01:52 PM
nevamind
Apr 16, 2004 03:36 AM
vtecdamian
Nov 27, 2003 12:26 PM
