b16a lower timing belt cover fit gsr?
Old Jan 1, 2007 | 11:01 AM
NA JDM GSR's Avatar
Default b16a lower timing belt cover fit gsr?
will a b16a lower timing belt cover fit a gsr???
Old Jan 1, 2007 | 01:24 PM
NA JDM GSR's Avatar
Default Re: b16a lower timing belt cover fit gsr? (NA JDM GSR)
Old Jan 1, 2007 | 01:27 PM
lVlemphizStylez's Avatar
there are two different b series timing belt covers...obd1 and obd2...As long as the engine is obd2 itll have the same lower cover...HOWEVER, that doesnt mean you cant use the obd1 cover as well..So answer is yes
Old Jul 31, 2010 | 06:19 PM
Chilaknet's Avatar
Can this be confirmed?
I just sent an obd2 oil pump back because my b16a3 lower timing cover wouldn't fit it.
If there is a way to make this fit PLEASE share because I cant find an obd1 oil pump anywhere
Old Aug 1, 2010 | 08:35 AM
redflaredcrx90's Avatar
this is true about the lower cover what year is ya motor
Old Aug 1, 2010 | 09:17 AM
Chilaknet's Avatar
95 Del Sol JDM p30 B16a. (I believe USDM Counterpart is the b16a3)
n0y
Feb 18, 2010 01:19 AM
CaseBone
Jun 19, 2007 06:27 AM
blackdude
Jan 25, 2006 07:39 PM
bootlegtrader
Aug 15, 2005 07:52 AM
EF9Civic
Feb 6, 2004 06:20 AM
