noticeable
Old Jan 1, 2007 | 01:07 AM
kixcrx's Avatar
Default noticeable
ok lets say one of the rear shocks is blown is it noticeable like does the car lean to one side alot or just little like about how much does it lower if one shock were to be blown in the rear on one side would it lower it enough to someone actually notice the car is crooked from back cause i think is does lower a little when shock is blown
Old Jan 1, 2007 | 10:15 AM
Hondasmo's Avatar
Default Re: noticeable (kixcrx)
Shocks and Struts are put on vehicles to absorb or dampen the shock of the road when goin over bumps and cracks. With no one in the car and on level pavment the car should sit level if you have a ride height problem most likely one of your springs are weak are not sittin on the strut correctly. A blown strut will make your car ride funny and bounce alot.
Old Jan 1, 2007 | 11:40 AM
Blue_EF's Avatar
Default Re: noticeable (Hondasmo)
my front right shock just went out and if u push down on the left side theres not much play....whern u push down on the fender on the right...it bounces up and down with a lotta play ...one way to check it
pbizzlegsr
Feb 23, 2004 12:55 PM
SpoonFedEF7
Jan 18, 2004 10:10 PM
SOJAMR1
Jan 11, 2003 01:05 AM
performula
10
Sep 18, 2002 04:22 PM
Gennady
Feb 22, 2002 11:35 AM
