wisconsin JANUARY 2007 Happy new year! (FS,WTB,TRADE)
Old Dec 31, 2006 | 04:37 PM
snowseeker's Avatar
Default wisconsin JANUARY 2007 Happy new year! (FS,WTB,TRADE)
WTB: 88-90 CRX side moldings, all of them. Also both door skirts (plastic trim on the bottom of the doors) with the metal strips and both fender skirts with metal straips. Also looking for a CRX rear bumper.
And have a happy new year!
Old Dec 31, 2006 | 06:16 PM
theinfamouskonrad's Avatar
Default Re: wisconsin JANUARY 2007 Happy new year! (snowseeker)
FS- Updated today!
Selling my fully built b20-v motor. Motor made 549 whp 343 torque at 24psi while peeling out on 4th on the dyno.
Bottom end
'00 b20z2 usdm block
RS machine sleeved 84.5mm
Micropolished Honda crank, all new Honda main/rod bearings, honda thrust washers
Crower 4340 steel Billet rods
JE 9:1 pistons
Block was also hot tanked, and main journals were align honed.
Exedy twin disc clutch for 92+ b-series
head
92 Jdm b16a head
Intake ports were mildly port/polished by DH-racing as well as 5 angle valve job
Ferrea stainless valves
all new Oem honda valve seals
supertech springs/retainers
Cometic head gasket
Golden eagle head studs
Edelbrock victorX manifold
Mr. Gasket fuel rail
68mm billet throttle body
Type r Camshafts with Hayame cam gears.
Motor was built by Mike at Extreme parts in august. Car was tuned on S300 Hondata by Dave at Whipfactory. Motor has less then 3000miles on it. I have all receipts for the motor etc.etc. Motor does not smoke, it has 185compression across the board. Great oil pressure. Only reason i'm selling it is because i wanna do something different in my crx for next year *hint k-series. This engine is basically bullet proof (with the right tuning of course) Price is $4500 with twin disc or $3800 without! What a steal! Motor costed me $10,000+ if your planning on going all out for next year this will save you a lot of $. I did have pictures of the motor getting assembled etc. but i lost them when my computer crashed pm me if interested or if you would like to check it out in person. Located in Milwaukee, WI.
[IMG][/IMG]
Selling MINT 15" rota Jmag's. Bought them about a month ago. You won't see 1 scratch on any of them! They are dirty in the picture, 100% polished. I have all original boxes and center caps for them. 2 of the tires are new g-force bfg's 205/55/15r. I will take off the other 2 tires which are bfg drag radials since i paid a lot for them. All you will need are 2 tires. Paid $550 for them. $499 picked up!
JDM ef8 crx front fog lights. 1 of them is still intact with just a hairline crack in it which you can't notice. Other one is cracked and worthless. Give me an offer on the 1 if you want it.
Hasport Mounts for 88-91 Civic/Crx with Hydro tranny. Complete kit, come with bolts (not pictured) 80A bushings-$399
Rear T bracket for 88-91 Civic/Crx for use with Hydro b-series tranny-$30
'97 Type R tranny-Completely Rebuilt by Mike at Extreme parts. Tranny has All new Carbon coated synchros by Gearspeed. 3rd+4th gear sleeve set was replaced with an OEM Honda one. New Honda countershaft and mainshaft top/bottom bearings as well as new seals. Tranny has less then 1500miles on it. Stock Type r LSD with 4.40 Final drive. -$1400 well worth it. Add up the synchros+other parts + labor and your basically getting the tranny for free.
i also have a stock hydro ITR tranny for $900. No grinds mint condition!
Schedule 40 stainless steel(glass beaded) butt-welded RAM style turbo manifold for b-series. Beautiful manifold, before pic of it glass beaded.. after pic looks nasty since it got all greased up with oil while removing it. Motor made 550whp with this manifold. Has 44mm Tial vband flange on it and it's turbine flange is a t3. It's not ac compatible but you can use power steering (just have to trim the top bracket a little bit) $399
Modified Avid racing traction bar for 88-91 Civic/Crx's. This is what all you turbo guys need if your 3" or even 4" downpipe hits the traction bar. Has mad clearance.$150 + your stock one.
Keizer 2 piece forged aluminum wheels 13". Mounted on them are 24.5" x 8" Mickey's but they are completely worn. Weigh 7.5 lb's each. -$300
RARE '91 LSD Y1 cable JDM tranny. NO grinds. picture of tranny before i installed it on my ef8. '92 JDM b16a engine is also for sale. Bone stock has 65K on it!! Runs great, doesn't burn any oil etc. Come check it out before you buy! I'm looking to sell the complete swap OR i'm willing to part out and sell everything seperately such as the tranny, complete b16 head or block. $800 for the complete engine, $600 for the lsd tranny!!
88 RHD crx rolling shell. All you need is a motor/tranny. $2000clean registered title. Could drop the price further if you don't need some of the add on parts it has. pm me for further details.
Aem V2 intake for 96-00 Civic dx, cx with throttle body mounted on top-$100!
B-series cable halfshaft/ b-series hydro halfshaft-$40 each
B-series hydro shift linkage-$60
TI-83plus graphing calcutor, perfect working condition-$25!
88-91 Crx rear bumper, no cracks etc. Has metal plate since the exhaust came off on the right, but you can cover it with a rear lip or something -$25
big yellow wastegate spring for tial 44mm wastegate (7 psi)-$15
92-95 Civic HB door panels-$15 for both picked up! ...they are a dark navy color
Gas pedal from 91 Crx si (will work on all 88-91 Civic/Crx's)-$10
Steering column w/ tilt option for 88-91 Civic/Crx-$30
P72 stock rods $10
JDM b20b AC compressor. Came off of Osaka Jdm motor 30k miles. MINT!! I believe this works with LS integra's as well-$20
95 Gsr power steering pump-$20
95 Gsr power steering pump brackets-$15
95 Gsr alternator brackets (top+bottom)-$10
95 Gsr Honda water pump-$15
95 Gsr Honda timing belt, like new only 10k miles on it-$10
95 Gsr upper/lower alternator brackets-$15
95 Gsr power steering brackets (have an extra 2 but they are just the lower ones)-$5 each
95 Gsr cam gears-$10
92-95 Civic front strut forks-$10
92-95 Civic steering column yoke-$1
94+ Integra drivers side motor mount bracket-$10
90-93 Integra front wheel hubs-$15
88-91 Civic/Crx coin tray-$5
88-91 Civic/Crx radiator T bracket-$10
88-91 Civic Center air vent-$5
88-91 Civic/Crx windshield washer reservoir-$5
88-91 Civic/Crx windshield Cowl-$5
88-91 Civic/Crx windshield wiper arms-$10
88-91 Civic/Crx hood latch-$5
88-91 Civic/Crx tekniq steering wheel hub for sparco steering wheels-$30
88-91 Civic/Crx hood popper-$2
88-91 Civic/Crx power mirror switch (not power folding mirrors)-$2
88-91 Civic/Crx Steering wheel hub for use w/ momo+sparco steering wheels. Brand is Tekniq high quality made in Italy-$30
I believe this is a 92-95 Civic power steering rack+pinion-$20! Price LOWERED!! $10 please come pick this up!
Cam gears for all b-series. Originally off Ctr cams. -$15 Lowered price $10
92-95 Civic Tenzo-r seat bracket w/ sliders for drivers side I also have some for 96-00 civic's. - $30 Included is another one i made, doesn't look as good, but still functions perfectly fine.
Msd blaster 2 coil-$25
Msd cap for use w/ external coil for ALL 88-91 ALL Civic/Crx/Integra's-$20
88-91 Civic/Crx fan
94+teg fan
92-00 Civic fan
$20 Each! Lowered price $15 each
Windows-
90-91 Civic Hb- Passenger's door window and passenger's quarter panel
89-91 Crx-Driver's door window *not pictured*
$35 each!
Selling for a friend-
Oem style CF hood from 98 Civic coupe-$200
vafc1-90
Stock JDM crx exhaust, removed from real ef8 crx-$100!
99-00 Si rims with tires, no curbage or scratches! $300
Old Jan 1, 2007 | 08:31 AM
snowseeker's Avatar
Check out my auctions in my sig, just put up some new things last night.
I also have a OBD0 B16a with a phantom grip tranny for 1600 or the entire swap for a 88-91 crx/civic with hasport mounts, hasport shift linkage, wiring, axles, everything you need for the swap for 1900.
I have many many othe civic and crx parts as well, let me know what you are looking for.
Old Jan 1, 2007 | 10:21 AM
HxCforever's Avatar
subscribed and a pm sent
Old Jan 1, 2007 | 10:50 AM
Tink2150's Avatar
looking for eg rear speaker setup. also looking for a set of seats for my eg. front and rears (eg or gsr). eg 4dr suspension wanted as well (cheap for my beater)
Old Jan 1, 2007 | 11:20 AM
Wild1's Avatar
Default Re: (Tink2150)
Looking for a rear trailing arm, drivers side.. Any body got 1 for sale for a EF or even for a 92-95 civic ... Preferably with good bushings.. Milwaukee area
Modified by Wild1 at 2:49 PM 1/1/2007
Old Jan 1, 2007 | 02:09 PM
BoostnF4I's Avatar
Default Re: (Wild1)
I'm selling my B20B. Compleat motor, Pulled it out of my car running about 62K on motor, factory exhaust manifold, factory intake manifold, I have Black factory valve cover. I also have all the mounts for a B series into a 92-95 civic (hydro). I'm asking 500 OBO for the motor and 100 OBO for the mounts. I also have a Lower rear tie bar for a 92-95 civic $50. Also have a spec stage one brand new clutch $150.
Call Nick at... 262-352-5459 if interested. THANKS
Old Jan 1, 2007 | 03:53 PM
LSEGHATCH's Avatar
Default Re: (BoostnF4I)
<U>GSR Head / AEM Cam Gears / Bosch Fuel Pumps / Precision Intercooler / & MORE</U>
https://honda-tech.com/zerothread?id=1833740
PICS in link
<U>WTB:</U>
HONDA or ACURA front seats. Doesn't matter what kind, as long as they are in good condition.
Old Jan 1, 2007 | 04:20 PM
Default Re: (LSEGHATCH)
Stealth style GSR intake manifold. Inside of it has been port/polished-$30
ecu's-...
obd0 91 pm9-10
obd0 91 pm5-10
obd0 88 pm6-10
obd0 89 pm6-10
obd0 91 pm9-10
obd0 91 pr4-20
obd1 93 pr4-20
obd1 94 p06-20
Tons of miscellanious EF parts, headlights, tail-lights, corner lights, cluster, resistor boxes, etc. etc. Ask me chances are i have it. I'm too lazy to take more pics. Selling for dirt cheap.
Modified by theinfamouskonrad at 4:22 PM 1/2/2007
Old Jan 2, 2007 | 03:13 PM
snowseeker's Avatar
Default Re: (theinfamouskonrad)
Just got in two cars that are going to be parted out.
One is a 91 civic hatch dx with a non running motor
Two is a 88 CRX SI with a good strong motor and tranny but the chassis is shot.
Both cars are bone stock and mostly there.
let me know if you need anything off any one of these cars.
Old Jan 2, 2007 | 04:41 PM
ls-v*2's Avatar
Default Re: (snowseeker)
alright i got a ef sedan shell and this swap, intentionally to use as a sort of beater seeing as how my da just got painted. after i got the shell, i found out the car was completely rewired for obd1. and i just dont have the time or will to deal with the mess. Im looking for trades or cash.. cable tranny(b16) b series parts. winter beater. just offer anything, this isnt much use to me so im willing to work something out. $700 obo for swap, id throw in the sedan shell for $1000 obo
heres the run down.
d16a6 w/si tranny
- Je pistons 9:1
- Crower rods
- Exospeed Race 6 cam
- mild port job with 4 degree angle on head
- new valves, springs, guides, seals, ect.
- New timing belt , water pump, tensioner
- cometic mls head gasket
- adjustable cam gear
- ACT 8lbs flywheel
- ACT xtreme pressure plate
- ACT street disc
Old Jan 3, 2007 | 05:02 AM
DisOnesAPlaya's Avatar
I am selling my entire leather set-up. Meaning the two front seats, the two back seats and the two door panels. They are in black. There is a rip on the driver seat it can be sew back on easily. The condition of the seat are great for its years. But its not brand spankin new. I am asking $450 or obo. Seat are located in milwaukee and will have to be pick up for my house. Interested IM ME..
Old Jan 3, 2007 | 06:49 AM
smkngsr's Avatar
Default Re: (ehDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smkngsr &raquo;</TD></TR><TR><TD CLASS="quote">Bought these wheels from Riley @ RijoEngineering for my S2000. the offsets are setup so that they will fit on the car fine w/ normal sized tires 225/255 or you could run up to a 285 with fender rolled. i sold my car and got a 350Z so i no longer need these wheels. take advantage of that by buying em now for cheap and you dont even have to wait to get them (all work multipiece wheels are special order)
<FONT SIZE="14">Specs:
18x8+58Front
18x10+58Rear</FONT>
Color: Feinheit Silver (custom color mixed by Work™ to have them w/ a very metallic/shiny finish.) the lips as you can see are full polish. and the wheels have a serial # plate on each wheel (nice little custom piece Work™ does.)
Condition: is brand new, never mounted... have all the original boxes so you know they will come as perfect as they are now. come w/ all the center caps and W engraved valve stems.
<FONT SIZE="15">Price: $2490+100 ship</FONT>
Old Jan 3, 2007 | 05:07 PM
92BluEH-3's Avatar
lulz
Default Re: (smkngsr)
F/S eg front brake rotor (1)
eg clear corners
eg factory intake system
4x114 steelies with some kind of snow tire i believe
stock dodge ram wheels with tires
WTB
turbo parts hit me up with what you got
Old Jan 4, 2007 | 02:46 PM
poorman's type-r's Avatar
* B A N N E D *
i have some of my junks that i didnt use for my poorman on SALE now... LMK what you want... All prices are OBO. Shipping will be extra unless STATED. Local pickup will be great. Otherwise, for the people on the border, i might be willing to meet up, if you pay for gas. Also, items are oily but i'll clean them once someone buy them.
Payment can be made by Money Order or through Paypal. If you're using Paypal please add the 3% fee. I'm also Paypal Verfied. My payal account is vangzboy@hotmail.com
JDM B16a Short Block Complete Perfect Condition w\49K - 300
GSR Oil Cooler - 50
GSR Stock Spark Plug Wires - 10
OBD2 GSR Cat Convertor - 75
97 GSR Crank (Perfect) w/51k - 150
GSR Complete Oil Pan (Perfect) - SOLD!!!
GSR TB w\ LS Pulley (TPS sensor is off) - 35
GSR Shift Linkage w/ Stabilizer Bar and Shifter - 95
96 GSR Dash (comes with all switches, most vent, guage bezel, no air bag or climate control) - 40, price lower 20... come pick this up...
GSR Stock Pressure Plate (51k) - 20
Drag DR-5 17in (50-70 thread left) - 400
OBD2a-OBD1 Wire Hareness Conversion (1k) - SOLD...
94-99 Teg Apexi N1 Axleback (10k) - SOLD!!!
96 LS Oil Pan Complete Perfect- 65 Shipped
OBD0 B16 IM - SOLD
OBD2 B16 IM - 20
OBD1 Timing Belt Cover - 25
B16 TB - 20
B16 Water Pipe (also got one for GSR and LS) - 20 (LS & GSR Sold)
B-Series Alt. Bracket - 20
B-Series Stock Cam Gear (off CTR Cams) - Sold...
B16 Main Caps w/ Bolts - 25 Shipped
DA Clutch Pedal - 20
Also, Got (No picture yet):
-94-97 GSR TEG front bumper, Pass Fender, Hood, and Back Bumper (all Red) (front bumper sold)
-Soon to be parting out a RED EG w/ front end gone\no motor.
-B-Series Termostat
-(2) OBD1 B-Series Alternator
-OBD1 and OBD2 GSR Distributor
-EG front bumper and hood (RED)
Old Jan 4, 2007 | 05:30 PM
Turbo_y8's Avatar
Default Re: wisconsin JANUARY 2007 Happy new year! (poorman's type-r)
FS
98 d16y8 head. 100k $50
Old Jan 4, 2007 | 06:39 PM
igotanintegra's Avatar
4 LS mesh with Michelin XGT V4, 2 tires are bald because idiots mounted it wrong.
stock 99 gsr shifter, will include leather shift **** (**** has little wear) best offer
off 99 gsr, i do have code. 80 obo
120 w/ spark plug cover, also have stock cover
off 99 gsr, best offer
buy this now or someone else will!!
Old Jan 5, 2007 | 04:12 PM
Turbo_y8's Avatar
Default Re: (igotanintegra)
98 y8 head 50
2 sets of stock y8 head bolts 10 each
1 set of y8 ARP head studswith assembly lube, directions in box. used for about 300 miles, only torqued to 65 ft lb. 25
obd II injector clips 10
y8 injecotrs 20
AEM tru power alt. pulley blue 10
new alt. belt 5
valve cover breather, new 5
38mm tial wastegate flange, new 15
t3 oil feed and return line gaskets. both 15
Old Jan 5, 2007 | 06:03 PM
89civicsi*'s Avatar
Default WTB: OBDO D-Series MPFI
Looking for a running OBDO D-series motor with MPFI. I need this motor in my car by 1/11 so I need to get a motor ASAP. I'm located in south central wisconsin, but i'm willing to drive to pick one up. Let me know what you've got.
Old Jan 7, 2007 | 10:36 AM
snowseeker's Avatar
Default Re: WTB: OBDO D-Series MPFI (89civicsi*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicsi* &raquo;</TD></TR><TR><TD CLASS="quote">Looking for a running OBDO D-series motor with MPFI. I need this motor in my car by 1/11 so I need to get a motor ASAP. I'm located in south central wisconsin, but i'm willing to drive to pick one up. Let me know what you've got. </TD></TR></TABLE>
Pmed
Old Jan 7, 2007 | 03:43 PM
dravesef's Avatar
WTB: 98 and up integra front bumper and head light and bumper lights also rear bumper
Old Jan 7, 2007 | 10:11 PM
Tyounin608's Avatar
Default Re: (dravesef)
subscribed
Old Jan 8, 2007 | 08:50 PM
Selling my black/red sparco seat. it comes with the rails for the driver seat and the harness. All parts are sparco brand. I am asking $225 or obo. Seat are located in milwaukee and will have to be pick up at my house. Interested IM ME..
Old Jan 9, 2007 | 10:30 AM
JDM_teh_WIN!!'s Avatar
Default Re: (DisOnesAPlaya)
I got stuff. Lets see if anyone wants it.
99-00 Si springs - $40
B16 Intake tube - OEM - $15
B16 Intake Manifold - $50
B16 Fuel Rail - $30
B16 Fuel Regulator - $15
B16 Throttle Body - $25
B16 Intake Manifold Bracket - $10
B16 AC Bracket - $20
B16 Upper Exhaust manifold/w Heat Shield - $10
JDM ITR Pistons - .25 OS - $65
1 Set of B16A2 Intake Rocker Arms - $250 Excellent condition
1 Set of RM Gen2 Intake/Exhaust Dual Valve Springs and Ti Retainers. $65
USDM ITR Seats - $700
96-98 Civic Airbags - $300
Rota Auto-X/Silver - $350
H&R Street Performance Coilovers -EK/EJ8- $500 http://www.kingmotorsports.com...at=44
96-00 Trunk carpet and Fiberboard deck - $20
Exedy Stage 1 Pressure Plate - $25
PM me if you are interested in any parts. Thanx.
Old Jan 9, 2007 | 01:09 PM
LSEGHATCH's Avatar
WTB: Cheap Honda/Acura or other form of transport with 4 wheels.
