major oil consumption, timing belt (?)
i have a 1999 honda accord lx sedan with the 2.3L I4 vtec engine and a manual transmission.
it has 140k miles, and i purchased it this spring with no maintenance history.
i am currently burning nearly a quart of oil every 100 miles!
there is not any noticeable 'pooling' under my car when parked, and very little blue smoke out the tail pipe (only seen at high rpm's).
could this be a timing belt issue?
other suggestions?
other suggestions?
No. But if you get the rings or valve guides replaced to fix the oil prob you should definatly have the timing belt, tensioner pulley and waterpump done at the same time.
Web_Head
Jan 15, 2002 11:19 PM
