is this possible? (chip for a NICE running stock Z6)
Old Dec 31, 2006 | 09:56 AM
Coltmorris's Avatar
Default is this possible? (chip for a NICE running stock Z6)
I have a d16a vtec...w/ a p28 and it runs soo badly. Super rich and rough as hell..ive taken essentially every step possible to ensure that this is NOT mechanical (diz, plugs, wires, seafoam, iacv,tps,map...i checked/ R&R'd them all...and i still get this very rich running rough little motor. Oh and I have a new o2 sensor....so, i heard that p28s run rich anyway...does anybody know of a chip/basemap that somebody just tuned a stock (bolt-ons) Z6 and made it run the best it could? I ask this bc tuning it myself would be A.hard bc i suck at it...and B. more costly than just buying a chip. Thanks
Old Dec 31, 2006 | 10:04 AM
green91's Avatar
p28 is the native ecu for a z6 it should run perfectly as long as everything else is correct.. check everything again lol.
Old Dec 31, 2006 | 10:07 AM
Coltmorris's Avatar
Default Re: (green91)
haha...well I dont know what else to do...im running so rich--what can I do? the motor has like 70k miles on it ...why would it be running so rough?
Old Dec 31, 2006 | 11:57 AM
Coltmorris's Avatar
Default Re: (Coltmorris)
i should also add that it runs worse the hotter the engine gets
Old Dec 31, 2006 | 12:06 PM
STREETWERKZ's Avatar
elaborate more on your engine setup...
D16a + vtec? mini-me? are you running a FPR or any sort of fuel management?
Old Dec 31, 2006 | 12:18 PM
Coltmorris's Avatar
Default Re: (STREETWERKZ)
ah k..sorry
D16A is the stamp on the block...its essentially a sohc zc vtec. its out of like a jdm 94 civic ex...has higher comp. than a Z6 but is pretty much the same. Its obd1 and im running the obd1 injectors as well. Im not running an fpr or any type of fuel management...its a bone stock motor (intake, header, test pipe/2.25 exhaust. ) running a virgin p28 as of now.
Old Dec 31, 2006 | 12:32 PM
oh, got ya.
lemme think about what it could be. i had a car running rich before, and it turned out the motor had the wrong type of spark plugs in it.
Old Dec 31, 2006 | 12:34 PM
Coltmorris's Avatar
any insight by you, werkz, would be much appreciated!! my plugs are NGK's ..theyre the choice of most Dseries owners i believe. also i should add this little bit of info: when its idling..if you listen you can hear little like blips from the exhaust..like teeny little pops that happen pretty sparatically.
edit: I timed the motor too..most people say when the timing advanced you run closer to the lean side, well i advanced my timing and i did not see ANY results. the engine still ran the same.
Old Dec 31, 2006 | 12:38 PM
what type of NGKs are they?
colder plugs could cause it to run rich.
Old Dec 31, 2006 | 12:42 PM
Coltmorris's Avatar
theyre the Vpowers...just the standard like 4 bucks a piece ones...I gapped them as well
Old Dec 31, 2006 | 12:43 PM
i would change the plugs. go to honda and get the ones specified for a D16z6.
they should be pretty cheap too.
Old Dec 31, 2006 | 12:46 PM
Coltmorris's Avatar
alright ill try that...just to clafiry though--when i say rich like I probed my o2 sensor joints and was getting around 75+mvs...honda says anything over 60 is rich so am i like dangerously rich? haha
Old Dec 31, 2006 | 12:48 PM
redzcstandardhatch's Avatar
something different
Default Re: is this possible? (Coltmorris)
do you have proper fuel pressure? is there an aftermarket regulator on it?
Old Dec 31, 2006 | 01:06 PM
Coltmorris's Avatar
Default Re: is this possible? (redzcstandardhatch)
no aftermarket reg...and yea we checked it
Old Dec 31, 2006 | 01:11 PM
something different
throwing any check engine lights? have you done a compression test, and checked for proper cam timing (timing belt wise)?
i hate it when cars dont run right..good luck
Old Dec 31, 2006 | 02:05 PM
Coltmorris's Avatar
well...the only code is for the o2 heater which only would affect the cold start emmissions really...umm heres the strange bit..we did a compression test and i dont know what happened but i gave it four cranks and it read 70-75 on all cyls...haha i think if it were really that low it like wouldnt run..so im very confused about that. I also do not know how to check the cam timing...you think that could be a variable? thanks for all the replies!
Old Dec 31, 2006 | 02:14 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">its a sohc zc vtec. </TD></TR></TABLE>
wtf? lol
Old Dec 31, 2006 | 02:31 PM
Tippyman's Avatar
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">
wtf? lol </TD></TR></TABLE>
There was a SOHC ZC VTEC. It's an OBD1 motor.
Old Dec 31, 2006 | 02:45 PM
Default Re: (Tippyman)
wow, guess i learn something new everyday
Old Dec 31, 2006 | 03:33 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">well...the only code is for the o2 heater which only would affect the cold start emmissions really...umm heres the strange bit..we did a compression test and i dont know what happened but i gave it four cranks and it read 70-75 on all cyls...haha i think if it were really that low it like wouldnt run..!</TD></TR></TABLE>
Ok, fix the O2 and make sure u have no CEL. Regarding the compression, try a different gauge. Those numbers are pretty low. Also, dont forget to disable the injectors and hold the throttle wide open while u crank.
What map sensor are u running? Maybe post a pic of your engine bay just so we can see what we're working with here.
Old Jan 1, 2007 | 09:08 AM
Coltmorris's Avatar
Default Re: is this possible? (fourthgenhatchB17)
hmm..i forgot to hold it at WOT when it was cranked..that could be it. heres a pic
Old Jan 2, 2007 | 10:59 AM
Coltmorris's Avatar
any other thoughts?
Old Jan 2, 2007 | 11:10 AM
amthompson's Avatar
well, on the plus side, i dont think you have a lot to worry about as far as it being harmful. you're going to foul some plugs, but running too rich is a hell of a lot safer than running lean.
still sucks, but im just saying, i dont Think its going to damage anything.
Old Jan 2, 2007 | 11:15 AM
ilikebigbutts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote"> when its idling..if you listen you can hear little like blips from the exhaust..like teeny little pops that happen pretty sparatically.</TD></TR></TABLE>
its misfiring, either because the plugs get fouled or something is wrong with the ign. system
ILBB
Old Jan 2, 2007 | 02:17 PM
Coltmorris's Avatar
Default Re: (ilikebigbutts)
yea..well i check the plugs regularly and theyre carbon-free, the wires and dizzy and nearly brand new. and i timed the engine spot on, so what else could be wrong with the ign system?
