engine ideas
Old Dec 30, 2006 | 08:58 PM
ekhatchswap's Avatar
Default engine ideas
I have a 98 EK hatch with a untouched 98 b18b swap. recently though ive pulled the motor and put back in the original d16y7 because of bad piston rings. So I have a few options... (A) do a total rebuild on the motor, aftermarket low compression pistons,rods,cams,springs,retainers,port & polish, & valves. I also plan to eventually turbo.
Or option (B) switch to a v-tec motor such as a b18c1
Or option (C) LS/VTEC with a b16 head
Im tring to find the best option. so I guess Im asking is vtec better than a built non-vtec with turbo? Thanks for your input on this one
Old Dec 30, 2006 | 09:11 PM
Syndacate's Avatar
Default Re: engine ideas (ekhatchswap)
Is rebuilding the LS while it's out of the car out of the question?
I say re-build that while it's out of the car. Then go LS/V or LS-T depending on your HP goals.
Old Dec 30, 2006 | 09:13 PM
93eg2james's Avatar
Default Re: engine ideas (Syndacate)
Vtec is great and all, but boost feels better.
Old Jan 1, 2007 | 09:16 AM
Default Re: engine ideas (93eg2james)
thanks anyone else? bump..
Old Jan 1, 2007 | 10:26 AM
ballerchild's Avatar
I say go boost, you'll get more power out of it as opposed to going LSvtec
Old Jan 1, 2007 | 10:29 AM
vltnolia's Avatar
Option A
b93hatch18
19
Feb 20, 2010 07:53 AM
esurds
15
May 5, 2009 04:22 PM
JDMike418
Jan 19, 2008 07:30 AM
Ekhatchman18
Apr 20, 2005 04:28 PM
Grubb
Feb 8, 2004 06:37 PM
