Need Help with headlights on a JDM front end EF
Old Dec 30, 2006 | 08:04 PM
90h22ef's Avatar
Default Need Help with headlights on a JDM front end EF
i was wondering if anyone knows, how the high beam and low beam work on a jdm front end. i have 91 hatch w/ H22 and need to complete registration. JDM front end has only one hole where as the US spec front end has two holes for a high beam and a low beam. what do i need to do in order to make the low beam and high beam work so that i can pass the light inspection.
Old Dec 30, 2006 | 08:16 PM
justseeingifitistaken's Avatar
Default Re: Need Help with headlights on a JDM front end EF (90h22ef)
cut stock harness, leave a few inches on original headlight harness in case you wanna go back ever. wire new headlight harnesses in, following same color codes. plug in h4 bulb. and tape off extra ground wire from each side (jdm uses one ground and two wires for hi/low beam instead of two bulbs. double filament bulb) your done be sure and solder all connections as well
Old Dec 30, 2006 | 08:52 PM
90h22ef's Avatar
Default Re: Need Help with headlights on a JDM front end EF (hondaJDMimports)
dwils
20
Jul 8, 2012 09:52 AM
aemintgsr
23
Jan 23, 2011 07:59 AM
xXx Justin xXx
Jul 22, 2003 06:56 PM
EVOTHIS
Jul 19, 2002 09:39 AM
TypeR 508
Jan 24, 2002 05:53 AM
