NEED HELP!
Old Dec 30, 2006 | 05:50 PM
RATED EG's Avatar
Default NEED HELP!
alright my buddy blew his stock D16Y7 so we got a new long block same motor we just swapped everything in. its starts but we are having problems the Check Engine light come on then off for a split second and it does it all the time and when it comes on it makes the motor bogg. and the speedo jumps too. even if the car is just park. i never ran into a problem like this before. some one help
Old Dec 30, 2006 | 05:55 PM
RATED EG's Avatar
Default Re: NEED HELP! (369 EG6)
yeah im sure it couldnt be the timing since it was a long block and bought from a shop. but i just put a new Dis. cap and rotor. along with plugs and wires. i swapped the wires with the old ones but still doing it. im thinking its electrical since its doing this weird flicker sh*t
Old Dec 30, 2006 | 07:04 PM
RATED EG's Avatar
Default Re: NEED HELP! (RATED EG)
TTT
Old Dec 30, 2006 | 07:12 PM
chrisw85's Avatar
I'm sure you've double checked all sensors are plugges into correct ones, some plugs look very similar and are even the same shape but different wire colors.
Its a long block yes, but if the motor is out it just makes sense for peace of mind to quickly change the timing belt, tensioner, and water pump. This also allows you to check and set the timing. Did the long block come with a dizzy? Put on your old one; unless it blew when the old motor went.
Old Dec 30, 2006 | 08:19 PM
RATED EG's Avatar
Default Re: (chrisw85)
the new long block did not come with a dizzy so i did use the old one. motor seems healthy doesnt smoke at all. the shop my friend bought it from said it had about 50-60K on it.
Old Dec 31, 2006 | 09:47 AM
RATED EG's Avatar
Default Re: (RATED EG)
TTT
Old Dec 31, 2006 | 09:49 AM
Archidictus's Avatar
Unceasing Measure
Toss a couple more generic ground wires on the engine and see if that makes the problem go away. Wouldn't be the first time I solved a Honda problem by aiding the finicky electrical system in finding a place to go
Old Dec 31, 2006 | 06:13 PM
chrisw85's Avatar
highly fetched, but could be something like a spark arcing in the wires which doesn't seem to be the case or it arcing/shorting in the cap/rotor....could be bad spark plugs? just a thought...
and yes, what archidictus said is often true, bad grounds can wreak havoc on a car's electrical...
Old Jan 1, 2007 | 03:22 PM
RATED EG's Avatar
well we figured out the problem it was a bad main fuel relay. got a new one and started right up just fine...thanks for the feedback guys
fujimi
Oct 8, 2012 11:01 AM
dcsports
Dec 7, 2008 06:54 PM
B204door
Aug 21, 2007 04:04 PM
nutball72
Apr 27, 2006 10:59 AM
sleeperteg
Jan 6, 2006 08:30 AM
