Hondata s300 install - need to add any wires to engine harness?
Old Dec 30, 2006 | 05:14 PM
B18EG6's Avatar
Default Hondata s300 install - need to add any wires to engine harness?
Hello-
Currently I am working on my engine wire harness, I am relooming most of it and using circular connectors mounted on the firewall.
I am going to use hondata s300 when I finish the car, and am trying to anticipate the addition to any wires within the main engine harness and reserve pin locations on the connectors. I already accounted for the wideband and have pins reserved for it, I am using a PLX m300.
Is there anything else that I will need to add to harness, now or even perhaps in the future? I need to finish the harness before I drop the motor back in
Thanks!
Seb
Old Dec 30, 2006 | 06:22 PM
kraig8's Avatar
no, unless you want to use the boost control function or nitrous.
Old Dec 30, 2006 | 07:48 PM
building boost's Avatar
how does the launch control (anti lag) work? any wires or clutch switches necessary?
Old Dec 30, 2006 | 11:17 PM
mtber's Avatar
Default Re: (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost &raquo;</TD></TR><TR><TD CLASS="quote">how does the launch control (anti lag) work? any wires or clutch switches necessary? </TD></TR></TABLE>
Reading the manual & playing with the software is always a good idea to pickup answers :-)
You can setup the launch control to be always on and use vehicle speed variables or you can set it up via a switch etc.
Old Dec 31, 2006 | 04:25 AM
ek9t72's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost &raquo;</TD></TR><TR><TD CLASS="quote">how does the launch control (anti lag) work? any wires or clutch switches necessary? </TD></TR></TABLE> just go to parameters and click on launch control u will see launch control activation I use D4scs {service connector switch} and u can set it to shut off at what ever mph u want
Old Dec 31, 2006 | 07:57 AM
B18EG6's Avatar
Default Re: (kraig8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kraig8 &raquo;</TD></TR><TR><TD CLASS="quote">no, unless you want to use the boost control function or nitrous.</TD></TR></TABLE>
I will more than likely run a separate boost controller. I plan on running these wires through the fenderwell or within the rain gutter.
Thanks for the answers everyone, I can be reasonably confident now that I wont need to make any big differences in the main engine harness.
Thanks! If anyone has some more input feel free to chime in
JDM_EK_JOE
Oct 17, 2007 02:23 PM
YoungKadafi
Welding / Fabrication
Apr 16, 2007 10:23 AM
mec. pedri
Nov 10, 2006 02:26 PM
B16CRXT
Dec 12, 2004 03:23 AM
JMD
Aug 2, 2003 06:08 PM
