Popping spring sound when door opens?
Old Dec 30, 2006 | 04:02 PM
D16Z6racing's Avatar
Default Popping spring sound when door opens?
90 CRX DX
When you open the driver door there is a 'pop' then the sound of a spring vibration. Like it's catching something just slightly and releasing. The door still opens all the way just fine, but I'm wondering where this "spring might be. I've stripped my old 89 CRX Si to the frame long ago, but remember seeing anything in the area that could be causing this.
Any ideas? Thanks HT-er's.
Old Dec 30, 2006 | 04:20 PM
omgwtfbbqcrx's Avatar
Default Re: Popping spring sound when door opens? (D16Z6racing)
look between the door hinges, there should be a little metal hinge type thing there with a pin inside of it. on mine, the weld broke loose and was letting the pin slip out of the body, actually, it keeps your door from opening more than its supposed to.
Old Dec 30, 2006 | 04:58 PM
s10cky's Avatar
its the hinge, it needs to be lubed up before it rips that sheet metal. there is no spring.
Old Dec 30, 2006 | 05:04 PM
pandarex's Avatar
Default Re: (s10cky)
mine has the same sound because the sheet metal around this is broken
Old Dec 30, 2006 | 05:26 PM
hondaman86's Avatar
mine was doing a similar sound and I found out that I leaned on my fender (aftermarket) and it bent in alittle, so the door was slightly rubbing on the fender.
Old Dec 30, 2006 | 05:39 PM
nk2k2's Avatar
Default Re: Popping spring sound when door opens? (hondaman86)
the hindge pin is old. there are brass bushings in there that are worn out due to old age. you need to replace those and it would be good as new.
Old Dec 30, 2006 | 05:52 PM
dr_latino999's Avatar
Default Re: Popping spring sound when door opens? (4g4d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d &raquo;</TD></TR><TR><TD CLASS="quote">the hindge pin is old. there are brass bushings in there that are worn out due to old age. you need to replace those and it would be good as new. </TD></TR></TABLE>Replace them with what, is their an OEM part that isn't a whole door? My Sedan has the same popping noise they are describing.
Old Dec 30, 2006 | 07:52 PM
92civicfreak's Avatar
Default Re: Popping spring sound when door opens? (omgwtfbbqcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omgwtfbbqcrx &raquo;</TD></TR><TR><TD CLASS="quote">look between the door hinges, there should be a little metal hinge type thing there with a pin inside of it. on mine, the weld broke loose and was letting the pin slip out of the body, actually, it keeps your door from opening more than its supposed to. </TD></TR></TABLE>
yep... my door opens about 90 degrees
Old Dec 31, 2006 | 02:44 PM
nk2k2's Avatar
Default Re: Popping spring sound when door opens? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Replace them with what, is their an OEM part that isn't a whole door? My Sedan has the same popping noise they are describing.</TD></TR></TABLE>
yeah the brass piece can be bought online on the Honda parts website. its like a few bucks. to replace it you need two people for the replacement of the piece.
Old Dec 31, 2006 | 02:48 PM
george34's Avatar
Make sure your fender is not dented(could happen from leaning on it) and the door hits the fender and then the door pops out.
Old Jan 1, 2007 | 07:50 AM
tcgordy's Avatar
omgwtfbbqcrx &lt;------- What he said, unfortunatly mine was like that when i bought it its the hinge the gold pin goes threw, if you notice its suppose to stay stationary but it moves ou well just put a few towels around the area and pop the pin out then weld the hinge so it is like new again. Im not so lucky guy before me slunge it all the way open and theres to dings in my door gap at the fender from hitting.
Old Jan 1, 2007 | 10:06 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">is their an OEM part that isn't a whole door?</TD></TR></TABLE>
Are you kidding me? There is a part number for every single part on the car, all the way down to individual bolts and washers and nuts.
higgunscrx
Jul 23, 2009 11:06 AM
young_tuner
Jun 27, 2008 02:52 PM
cegglestn
Mar 7, 2008 12:07 PM
