b16a in fit
just a question. i did search and i didn't find anything. i just wanted to know if it was at all possible. and if so, would there be any room for anything else afterwards?
thank you.
flame away.
thank you.
flame away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning »</TD></TR><TR><TD CLASS="quote">but why the hell would you want to put a 8 year old engine in a new car?</TD></TR></TABLE>
because not everyone has 11k to but a K motor in
and because the L15's suck. a lot.
Anything is possible, but it would be problematic.
First, any B16 will be older than the car, so you'd likely have problems with inspections or smog checks in some states (like CA).
Also, the B16 rotates the opposite direction from later K-series and L-series engines, and its intake and exhaust sides are opposite. This means you'd have a couple of options:
Install a b-series engine/trans with the transmission on the opposite side of the car (passenger's side). This would require some custom fabrication for at least the shift linkage and clutch... and probably more. Another problem here is the crossmember behind the and below the engine in the Fit. Routing the b-series exhaust around it would be difficult because b-series headers pass below the oil pan.
Install a b-series engine/trans with the trans oriented the same way as the stock Fit. This would also require custom fabrication for at least the shift linkage and clutch if it would work at all. It might make exhaust routing easier, but an intake manifold might not fit, and it might be nearly impossible to connect linkages to the transmission.
So... if you really want to do a swap, I think you're better off with a k-series. Kits are in the works for k-series swaps, and you'll avoid lots of problems you will encounter with a b-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowww_DCfour »</TD></TR><TR><TD CLASS="quote">because not everyone has 11k to but a K motor in
So, you'd spend $5k (conservatively) to put an 8 year-old, god-only-knows-the-mileage engine into a brand-new, warrantied car, which would run low 15's if you didn't turbo it???
And as stated earlier, backdating engines is not smog legal in a lot of places.
</TD></TR></TABLE>So, you'd spend $5k (conservatively) to put an 8 year-old, god-only-knows-the-mileage engine into a brand-new, warrantied car, which would run low 15's if you didn't turbo it???
all this would happen after the warranty. shouldn't that be a given. and i know they K and B spin in opposite directions.
but if you read the top, just a question. but thank you for answering it
yes the B series and the K series swaps have been done.....the Fits been out for a few years overseas so the JDM market has done some of these already
as for the L15 sucking.... stock its not at all thrilling....although i have riden in the Jackson Racing supercharged fit.....L15 with S/C making b16 numbers.....very very fast and fun...should be out early 07
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano Sol »</TD></TR><TR><TD CLASS="quote">yes the B series and the K series swaps have been done.....the Fits been out for a few years overseas so the JDM market has done some of these already
as for the L15 sucking.... stock its not at all thrilling....although i have riden in the Jackson Racing supercharged fit.....L15 with S/C making b16 numbers.....very very fast and fun...should be out early 07</TD></TR></TABLE>
Please post pics or links of a b or k swapped Fit in Japan. I am definitely interested becasue I have only seen bolt on turbos here.
http://www.n1concepts.com/
click or Copy/paste in URL bar....K20 Fit.....and yes its a JDM Fit (right hand drive)
still trying to find the b series fit.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano Sol »</TD></TR><TR><TD CLASS="quote">found it.....enjoy.
That's hot.
That's hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrkopropo »</TD></TR><TR><TD CLASS="quote">http://www.garagefk.com/ Here's one from japan</TD></TR></TABLE>
Thanks! So far it looks like that is the only one in Japan.
