LS/VTEC Swap
Old Dec 30, 2006 | 01:27 PM
3Rd GeAr PuLl's Avatar
Default LS/VTEC Swap
I have a ls/vtec long block with everything and a lsd tranny bolted onto it.
I have axles, mounts, ecu, and obd1 jumper harness. is there anything else i need to complete this swap into an 96 ek .
And i was wondwering if i could use my stcok d series linkages to use in the swap and also do i habe to have a vtec wiring harness or can i just wire in vtec
Old Dec 30, 2006 | 01:46 PM
pdiggitydogg's Avatar
As long as you have the "correct" mounts/brackets (em1)...
You need b series linkage.
You can wire in vtec OR swap in a harness - your choice. Search for how to wire vtec.
91 DA B18B1
Mar 25, 2011 08:15 AM
GSR936
Feb 18, 2010 05:55 AM
rollintegra
Dec 10, 2008 10:55 AM
ungers_21
Jun 16, 2008 05:02 PM
zx2gotboost
Mar 2, 2006 03:36 PM
