vtec help
Old Dec 30, 2006 | 01:19 PM
that1guywithhair's Avatar
Default vtec help
i just swapped a b16a into a 91 hatch and cant get the vtec working when i have everything hooked up i think correctly and the code comes up for the ignition and it doesnt start it wont spark until you turn the key to off and it sparks one time then if i unplug the vtec oil pressure sensor it starts up but the vtec doesnt work and the ignition code doesnt come up anymore but the vtec solenoid comes up and the throttle position sensor comes up and if you drive it for a while the knock sensor also comes up anyone have any ideas on the problem?
Old Dec 30, 2006 | 01:22 PM
dr_latino999's Avatar
Default Re: vtec help (that1guywithhair)
Are you running OBD-0 or OBD-1?
What ECU are you using?
Did you do all the wiring yourself?
Was the chassis MPFI wired before or did you do that and the extra B16 wiring at the same time?
Old Dec 30, 2006 | 01:30 PM
pwo ant it was already mpfi before
Old Dec 30, 2006 | 01:31 PM
and yeah i did it myself with the hasport wiring harness
Old Dec 30, 2006 | 01:35 PM
Default Re: (that1guywithhair)
You say it won't start UNTIL you unplug the VTEC Oil Pressure Sensor, is that every time or was that a one time incident? It sounds to me so far that a wire is crossed in the harness as the O.P.S isn't integral for any starting purpose, or completing any circuit other then it's own.
Old Dec 30, 2006 | 01:38 PM
yeah if i either unplug it or unhook the ground it will start but if i unhook the blue wire and leave the ground connected it doesnt start
Old Dec 30, 2006 | 02:03 PM
anyone?
90civicSiRacer
Oct 1, 2007 02:36 PM
91EF_Si
Sep 21, 2007 05:52 PM
quicksol95
Mar 19, 2004 01:50 PM
pr3crx
Feb 5, 2004 10:04 AM
