Weird problem with fan motor and stereo.
Old Dec 30, 2006 | 12:33 PM
2point2's Avatar
Default Weird problem with fan motor and stereo.
So I took out my fan motor assembly box thing from my 88 Civic DX today because it wasn't working. (GOD I HATE AC!) No fuses were blown and a really bad burning wire/burning solder smell filled the car before the motor stopped working. 99% sure it was the fan motor. The weird thing was that the stereo stopped working as well.. thought it was just because the motor was shorting out.
Tested the fan motor on the bench and IT WORKED. Figured some junk just got on the motor brushes and it just need to be banged around a bit.
So I put everything back together and everything worked again.. (even the stereo)
now the fan motor slows down from time to time and the stereo sort of cuts out..
Anyone have any ideas? thought I'd ask first before looking at some wiring diagrams.
Thanks.
Old Dec 31, 2006 | 03:59 AM
2point2's Avatar
fan doesn't work again.
time to look at some wiring diagrams.
Old Dec 31, 2006 | 07:04 AM
Hondasmo's Avatar
Default Re: (2point2)
That is weird ... I would look at the wiring schematic and see what those 2 circuts have in common whether it be a ground or a power source. 99% of most electrical problems is a loose connection of some sort ....
Old Dec 31, 2006 | 07:23 AM
2point2's Avatar
Default Re: (Hondasmo)
I think it's the ignition switch!
Old Dec 31, 2006 | 09:42 AM
welfarepc's Avatar
sounds like a loose connection thats sparking while jumping and burning some plastic shielding off the wire... thats my guess... check your grounds and look for burnt wires.
Dan
Ramanaidoo
Honda CR-V & Element
Jan 10, 2012 03:38 PM
johnone
Jun 11, 2010 04:13 PM
eg:R
Mar 26, 2008 11:05 AM
