Need help identifying injectors if they were made for 01 ITR
Old Dec 30, 2006 | 12:29 PM
exvelocity's Avatar
Default Need help identifying injectors if they were made for 01 ITR
Hi, trying to see if any of you guys can help me identify injectors I bought, the seller claims they were pulled from 2001 Integra Type-R,there are numbers stamped in the plastic part of the injectors,
any help would be appreciated
Also what is the flow rate on theese?, will they work fine in 00 Si?
Thanks alot ,
Stefan
Old Dec 30, 2006 | 12:55 PM
GO-FIGHT-KILL's Avatar
All B-Series Injectors are the same size... OBDII B-Series Injectors have a different clip, that's it.
Old Dec 30, 2006 | 02:51 PM
exvelocity's Avatar
Default Re: (GO-FIGHT-KILL)
I know they are same size,I doubt they have same flow rates,240s on Si ,and I've heard GS-R has 270s, but I need to know visually if they are any different(the ones I have just bought off 01 ITR)
Old Dec 30, 2006 | 03:00 PM
92TypeR's Avatar
FSAE
Default Re: (exvelocity)
They are the same size. As in they all flow 240cc/min at 41psi.
The only difference between any B-series injector is the harness clip.
Old Dec 30, 2006 | 07:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exvelocity &raquo;</TD></TR><TR><TD CLASS="quote">I know they are same size,I doubt they have same flow rates,240s on Si ,and I've heard GS-R has 270s, but I need to know visually if they are any different(the ones I have just bought off 01 ITR)</TD></TR></TABLE>
Like I said... All B-Series Injectors are the SAME, the only difference is OBDII has different clips.
Old Dec 31, 2006 | 06:12 PM
SlapSmak's Avatar
Default Re: Need help identifying injectors if they were made for 01 ITR (exvelocity)
Stefan, best way to tell is to send them off to RC Engineering and have them flow tested and cleaned. All B series injectors are 240cc, unless they are Lude injectors, which are 290cc. I am in Jax also and have a couple of sets of 240's sitting around. If you want to compare, IM me and you can take a look at them this coming week.
Old Jan 1, 2007 | 08:55 PM
exvelocity's Avatar
Default Re: Need help identifying injectors if they were made for 01 ITR (SlapSmak)
well, the problem I have ,is the car I'm working on was a turbo car, so stock injector conectors were cut off and replaced with some aftermarket ones , when I bought the car , the ECU,complete exhaust,fuel rail, injectors were already gone,besides the headlights,front bumper,grille, right fender and some interior pieces,
So now I need to figure out which conectors will work with theese injectors, since I will not be installing another turbo on it, but get it back to stock,well maybe not stock but rather back to NA
Old Jan 5, 2007 | 11:07 AM
SlapSmak's Avatar
I have 240 CC injectors for OBD1 and OBD2 as well as the OBD1 pigtails from RC engineering.. let me know if you need some help with figuring it out.
Old Jan 5, 2007 | 11:19 AM
exvelocity's Avatar
well, I have two sets of injectors, one set off 00 si and other supposedly off 01 itr,I need a set of pigtails to conver harness back to stock, if you got some, give me a call 721-3788. thanks
Stefan
Modified by exvelocity at 1:59 PM 1/5/2007
Old Jan 5, 2007 | 11:34 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exvelocity &raquo;</TD></TR><TR><TD CLASS="quote">well, I have two sets of injectors, one set off 00 si and other supposedly off 01 itr,I need a set of pigtails to conver harness back to stock, if you got some, give me a call 721-3788. thanks
Stefan</TD></TR></TABLE>
if you're creative enough, then you don't need to get obd2 clips. you can shave obd2 injectors a bit and make them fit into obd1 clips - worked in my case or go to junkyard and get obd2 clips
Old Jan 5, 2007 | 01:02 PM
exvelocity's Avatar
Default Re: Need help identifying injectors if they were made for 01 ITR (vtec.dc2)
my injectors won't clip into the ghetto fabulous clips that someone installed , they don't even look close to OBDI or OBDII
Old Jan 5, 2007 | 01:18 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exvelocity &raquo;</TD></TR><TR><TD CLASS="quote">my injectors won't clip into the ghetto fabulous clips that someone installed , they don't even look close to OBDI or OBDII</TD></TR></TABLE>
in that case, junkyard unless someone has 'em on here
tatted91rex
Oct 22, 2011 11:43 PM
jksmith
Apr 19, 2008 09:56 AM
b18cx
Feb 28, 2004 09:45 AM
dohcter g
Nov 16, 2003 06:12 AM
gotjesus
Nov 2, 2003 12:18 PM
