b16a misfire
Old Dec 30, 2006 | 11:48 AM
pompom's Avatar
Default b16a misfire
i have a 91 civic with a jdm b16a swapped into it. recently when it start getting cold, the car would misfire occasionally. now it wont stop, once i start it its already misfire, the car runs extrememly rich. i have no idea what to do could somebody point me in the right direction?
Old Dec 30, 2006 | 12:01 PM
KURUPTinc's Avatar
Default Re: b16a misfire (pompom)
have you pulled your spark plugs yet? is it consuming oil, coolant?
Old Dec 30, 2006 | 12:55 PM
pompom's Avatar
Default Re: b16a misfire (KURUPTinc)
i replaced the spark plugs and it doesnt seem to be using an excess amount of oil or coolant
Old Dec 30, 2006 | 06:18 PM
AndrePerras's Avatar
random misfire? or a cylinder in particular ? You can check this by pullin the plugs and grounding them to your engine (dont do this for extended amounts of time as you may burn a coil in your dizzy)
If it is a random misfire, then your dizzy is probably dying out, if it is isolated to a cylinder in particular, check your spark plug wire for continuity, resistance (Short ones should be like 4k ohms, and the longest like 10k ohms)
doug1978
Engine Management and Tuning
11
Dec 23, 2009 09:17 AM
95civhb
Mar 2, 2009 05:49 AM
blaze the chemi
Feb 7, 2008 06:43 PM
knowles_101
Dec 19, 2004 09:15 PM
