Does Factory Integra Head Unit have AUX input??????????????
Old Dec 30, 2006 | 10:55 AM
DCStreetHtch's Avatar
Default Does Factory Integra Head Unit have AUX input??????????????
I want to hook up an adapter to play my IPOD, wondering if anyone can quickly confirm yes or no before i have to tear up my dash to find out...
PRECIATE IT!!!!
Old Dec 30, 2006 | 11:03 AM
B18C_EJ8's Avatar
No.
It may, however, have a cd changer port into which you can plug an aux-input adapter...
Old Dec 30, 2006 | 10:08 PM
LSRracing95's Avatar
Default Re: (B18C_EJ8)
ditto the above..
i cant remember the oem unit having aux input, id have to take a look at mine.
Old Dec 30, 2006 | 11:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
It may, however, have a cd changer port into which you can plug an aux-input adapter...</TD></TR></TABLE>
can someone confirm????
Old Dec 31, 2006 | 04:04 AM
mrdeadman's Avatar
They let me pick
Default Re: (DCStreetHtch)
It does have a cd changer port.
Old Dec 31, 2006 | 05:08 AM
B18C_EJ8's Avatar
Does the deck have CD changer controls on the front? Or any other buttons relating to a "CD" function? If so, the plug is there.
Old Dec 31, 2006 | 09:18 AM
fcm's Avatar
fcm
Old Fart
My 94LS has a CD port, but the only switch/button is "mode" it will only switch from cass. to radio, unless a change is plugged in.
I have yet to run across an Integra, [94 up] that did not have a changer controller HU.
PAC... http://www.pac-audio.com/ will have the AUX input adaptor.
PIE ... http://www.pie.net/store/index...D=233 has the iPod interface, and the AUX input... http://www.pie.net/store/index...ID=22
SoundGate... http://www.soundgate.com/index...d=196& has AUX input adaptors... and iPod docking port adaptors... http://www.soundgate.com/index...d=239&
Blitzsafe... http://www.blitzsafe.com/blitz....html has AUX input adaptors and an iPod interface adaptor... http://www.blitzsafe.com/blitz....html 94
Old Dec 31, 2006 | 10:35 AM
good lookin out guys, sounds like the kit i am about to buy will work perfectly for the stock integra cd player
Old Jan 3, 2007 | 02:47 AM
Jollybandit's Avatar
I believe, you need a cheater plug that has a link between to of the pins and then you can feed an extenal single stereo audio signal in. but this is on certain integra audio systems (new models have two systems one is a BOSE based system with aditional amps for front & rear speakers and boot sub, the other a single cd deck with a single socket in both case if you have the pin outs you can work it out)
Old Jan 3, 2007 | 04:19 AM
stockredej1's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
PIE ... http://www.pie.net/store/index...D=233 </TD></TR></TABLE>
So all you would need to get is something like this? Would it charge the ipod to im assuming?
Old Jan 3, 2007 | 05:23 AM
fcm's Avatar
fcm
Old Fart
Default Re: (stockredej1)
Yes, most adaptors like those, [using CD changer port] will also charge the iPod. 94
Old Jan 3, 2007 | 06:43 AM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Yes, most adaptors like those, [using CD changer port] will also charge the iPod. 94 </TD></TR></TABLE>
Thanks, il have to pick one of these up
Old Jan 3, 2007 | 08:54 AM
fcm's Avatar
fcm
Old Fart
I would pull the HU and make sure you have the CD changer port before you spend the money. 94
Old Jan 3, 2007 | 09:05 AM
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">I would pull the HU and make sure you have the CD changer port before you spend the money. 94</TD></TR></TABLE>
Well its got a 6 disk changer in it now so im assuming i do haha.
Old Jan 3, 2007 | 01:53 PM
fcm's Avatar
fcm
Old Fart
OIC, your not the OP
Then make sure you get one that will allow you to keep the changer, [if you want to keep it], they will cost more. 94
Old Jan 4, 2007 | 09:07 PM
I am kind of in the mood to contribute to HT... i am waiting on a collection of parts to set up the ipod in my car with my factory cd player.
I plan to post a how-to
stay tuned
skwim
Audio / Security / Video
Aug 31, 2009 04:46 PM
EFsSuck
Feb 15, 2009 11:05 AM
vinuneuro
Jul 4, 2006 09:25 PM
jb.
Apr 5, 2005 10:15 AM
eg686
Mar 18, 2004 08:42 PM
