2001 Accord V6 Timing belt change, comprehensive parts list please
Old Dec 30, 2006 | 12:01 AM
banditt007's Avatar
Default 2001 Accord V6 Timing belt change, comprehensive parts list please
I would like to do a timing belt job, as well as replace preventitive maintainence items 'while i'm in there'. I'd also like to know what brands i should stay away from for things like the water pump/tentioners. I have the 98-01 service manual supplement, pulished by the honda motor co. However other tips from the seasoned guys here would be <U>GREATLY</U> appreciated. I have yet to 'dig into' the motor section of this car, just suspension/brakes/oil changes.
So here is what i have so far, please feel free to add anything i've missed or tell me if its not worth to replace an item on the list, your $0.02/tips ect
SPECIALTY TOOLS?
I hear that i need one for the crank bolt. however can this be removed with a 1/2" 500ftlbs impact gun? I hear its not good to use an impact gun. Perhaps i could use one if i put a block of wood between the crank and the block via dropping the oil pan? or blip the starter w/ a breaker bar attached?
belt tention release arm ?
PARTS
Alt/AC belt
PS belt
Timing belt
Alt belt tentioner (oil inside?, reoil? replace?)
Dip stick o-ring
Timing belt tentioner
Idler pulley
water pump/o-ring/coolant
thermostate/thermo rubber seal (i also see 2 other flat paper-type gaskets listed for the thermostate housing seal firewall/radiator side ? ?)
cam/crank seals/oil pump pulley seal (what are the other pulley type seals?)
Thanks for the help
Old Dec 31, 2006 | 03:59 PM
banditt007's Avatar
Default Re: 2001 Accord V6 Timing belt change, comprehensive parts list please (banditt007)
anyone?
dlewis2583
Apr 25, 2012 10:02 AM
bokonon
Aug 25, 2009 04:34 PM
904d
Jul 30, 2009 11:26 AM
D21X
Aug 21, 2006 04:54 PM
TERRA
Jan 23, 2002 08:57 AM
