d16a1 head on DOHC ZC?
Old Dec 29, 2006 | 10:56 PM
White91EF's Avatar
Default d16a1 head on DOHC ZC?
Like the title says is this possible? Cracked my ZC head so I'm looking for a new one... I searched and heard yes and no and everything in between, anyone know for sure?
Old Dec 29, 2006 | 11:41 PM
IP RACING's Avatar
Default Re: d16a1 head on DOHC ZC? (White91EF)
no! If Im not mistaken no other head besides the zc head fits the zc block...
dont take it as 100% right though.. Im like 98% sure
Old Dec 29, 2006 | 11:46 PM
89efDUSTY's Avatar
i dont think you can....i have d16a1 let me know because if so...i may need to do your reverse swap...i have to change my head gasket tomorrow...
Old Dec 30, 2006 | 01:33 AM
djphonics's Avatar
Default Re: d16a1 head on DOHC ZC? (89efDUSTY)
Seems like it might be possible. They are very similar. Pistons for ZC/A1 are the same. I can't verify if the head bolts and dowel pins line up. Ask the question on http://www.thezcr.com. Somebody will know for sure.
Old Dec 30, 2006 | 01:49 AM
nexter's Avatar
Default Re: d16a1 head on DOHC ZC? (djphonics)
yes the d16 head works i did that swap a few years back thing ran like a champ......with some gsr injectors and a p72 ecu........
Old Dec 31, 2006 | 05:37 AM
Chaos3252006's Avatar
Yup I'm rocking a DOHC ZC MLS headgasket in my d16a1, everything lined up.
Old Dec 31, 2006 | 07:07 AM
jlicrx's Avatar
will it bolt on? yes, but the heads are not the same - 86-87 D16A1 heads have different distributor and cylinder position sensor mounting locations - 88-89 D16A1 have distributor and cylinder sensor like the ZC - all 86-89 D16A1 heads have different bolt hole locations on the timing belt end for attaching the timing cover, etc. - all 86-89 D16A1 heads have valve cover bolt locations that are not the same as the ZC
Old Dec 31, 2006 | 04:24 PM
doubleA's Avatar
Default Re: d16a1 head on DOHC ZC? (jlicrx)
Ive done it. the drivers side motor mount bolts to the head in two places on the d16a1 head. The zc head only has one mounting hole. So you have to grind a little off the lower mount on the d16a1 head. otherwise everything else is good to go. Ive got a pic of the two different heads next to each other its my picture hosting site is preventing me from hosting them
Old Dec 31, 2006 | 11:31 PM
doubleA's Avatar
Default Re: d16a1 head on DOHC ZC? (doubleA)
here is the pic, top is zc bottom is d16a1
chris riz
12
Sep 22, 2011 12:34 PM
90si-rex
Sep 13, 2009 09:29 PM
BigPlansNoMoney
Jan 23, 2005 11:20 PM
CRX_RUS2
Nov 26, 2004 12:52 AM
