caster problem
Old Dec 29, 2006 | 10:54 PM
CRX 2.0V-T's Avatar
Default caster problem
My caster is off now
3.7 right and 2.6 left
will traction bar fix this problem?
what to do to do fix caster?
Old Dec 29, 2006 | 11:30 PM
ProjectDarkBlack's Avatar
Default Re: caster problem (Lak of Speed)
a traction bar will make it so you can adjust caster, that would be a good bet.
Old Dec 29, 2006 | 11:57 PM
abnaasefmb's Avatar
make sure that you did not put the right on the left and the left. front upper control arms.
Old Dec 30, 2006 | 06:52 AM
fireant's Avatar
Default Re: caster problem (abnaasefmb)
First things first, replace the radius rod bushings with some new ones from ES. It could just be a dead bushing.
From there, you can get another alignment reading done, but bring some washers that will fit over the radius rod. You can put them on the inner side of where the radius rod connects to the front crossmember...as long as you can find a shop that is friendly enough to let you do that kind of thing.
Old Dec 31, 2006 | 07:03 PM
CRX 2.0V-T's Avatar
Default Re: caster problem (fireant)
pretty tired of stock crossmember (that thing hugh) so i dont think im gonna fix that, more likely im getting traction bar replace the whole thing (one stone hit three birds, ya know) to fix the caster plus getting some traction and clear alot of space.
I like how fullrace traction bar is but it required to use its radiator which i dont want to. and Jimfab is out of bussiness(look like it)
looking for a traction bar with two requirements
1. like fullrace
2. use stock or haft size civic rad.
any1 know where can i get traction bar like Jimfab? u know, big bang for buck.
Old Jan 7, 2007 | 07:12 PM
CRX 2.0V-T's Avatar
bump
Old Jan 7, 2007 | 07:40 PM
mar778c's Avatar
Community Builder
Community Influencer
I got the JKmotorsports traction bar from LSDmotorsports. It has mounts for the new half size radiators. The mounts make your set-up just like stock. Also, it has the double ended hind joints just like full-race, etc.
myownboot
Suspension & Brakes
14
Jun 26, 2013 06:10 PM
boost4life1
May 2, 2012 11:59 AM
JustinHoMi
Suspension & Brakes
Mar 9, 2006 09:35 AM
Mr.Saturn
11
Feb 23, 2004 11:52 PM
