integras cable to hydro conversion on crx
Old Dec 29, 2006 | 09:31 PM
russianswty's Avatar
Default integras cable to hydro conversion on crx
Has anybody ever used the kit they sell for the DA's on the EF
to use the hydro tranny in our older vehicles?
thanks
Old Dec 30, 2006 | 01:26 PM
ChickenH's Avatar
Default Re: integras cable to hydro conversion on crx (russianswty)
I want to know this also i need to put a usdm type r trans in my crx.
Ive done it the other way around using a cable transmission on a hydraulic car with a Hasport kit.
Old Dec 30, 2006 | 01:38 PM
dr_latino999's Avatar
Hasport has been selling the kit for the use of Hydro transmissions (B-Series anyways) in our chassis for quite some time, I know if you open up the search button you'll find commentary on it.
Old Jan 1, 2007 | 11:09 AM
Default Re: integras cable to hydro conversion on crx (dr_latino999)
but has anybody successfuly swapped one over from a da to an ef?
Old Jan 1, 2007 | 02:32 PM
.Manny.'s Avatar
Touching My Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russianswty &raquo;</TD></TR><TR><TD CLASS="quote">but has anybody successfuly swapped one over from a da to an ef?</TD></TR></TABLE>
are you serious???? people have successfully done k swaps and h swaps and b swaps...
look up hasport.com
end of thread, and use the search button
Old Jan 1, 2007 | 11:12 PM
Default Re: integras cable to hydro conversion on crx (90_EF_Si)
ok obviusly some people arent READING correctly, and cant answer a god damn
question and just try to be dicks.
My question was has some one used the hasport or anybody else's kit that is meant for the integra to under go that swap. and put that same kit on the crx?
I know they make them for the ef's and the da's but they claim to have differant part numbers, but that just might be becuase the da has to come with a different mount.
But anyhow has anybody tried this?
Old Jan 20, 2007 | 07:03 AM
RyanA's Avatar
If you are asking if the engine/tranny mounts are the same between an EF and a DA, the answer is no. They do not interchange like an EG and DC do....
Old Jan 20, 2007 | 11:50 AM
Default Re: integras cable to hydro conversion on crx (RyanA)
no thats not what I was asking, but I had figured it out, it works just fine.
The part that I was interested is the hydro to cable conversion levers that you put on your hydro tranny to make it work in a cable car. So I wanted to know if the integra lever's are the same for the crx. Besides the mounts.
Em1Raposo316
10
Aug 29, 2013 08:32 AM
Super Chicken
Dec 28, 2006 04:40 PM
REX VT
Jan 22, 2004 10:56 AM
