wiring prolem in eg hatch
Old Dec 29, 2006 | 08:36 PM
92 civic's Avatar
Default wiring prolem in eg hatch
i got an eg hatch when i click the switch over to the parking lights they don't come on at all [ no corner markers, or taillights]. but when i click it to the head light point on the switch the head lights are the only thing that comes on. again that means no markers and no taillights.
i checked all the fuses and they were all fine
Old Dec 29, 2006 | 09:01 PM
qat727's Avatar
Default Re: wiring prolem in eg hatch (92 civic)
Is this a recent problem, or have they never worked for you? Are all your switches and everything plugged in?
Old Dec 30, 2006 | 02:45 AM
RC000E's Avatar
Default Re: wiring prolem in eg hatch (qat727)
This is a fairly common issue for EG's. I have repaired several cars with this issue. Sometimes it will only happen when it is cold outside, then gets progressively worse.
The answer to the problem is the stalk itself that the headlight/parking light switch is on...gauranteed...not wiring issues. You can usually feel a little drag in the switch. You no longer have a defined...click..click in each position. I have seen them go bad and still feel fine though.
The [the stalks] are pretty easy to change. You don't even have to take the steering wheel off, just turn it at an angle. You remove the plastic housings around the column, remove some screws and the stalk unplugs. Find a parts car or junkyard
This is 100% gauranteed your problem.
Old Jan 3, 2007 | 09:52 AM
92 civic's Avatar
Default Re: wiring prolem in eg hatch (RC000E)
i was told this is a common problem and someone else told me it was the switch but i wnted to get more points of veiw on the problem, now that 2 people told me it is the switch i will replace it
thanks
Wdpfreak145
10
Dec 8, 2010 10:18 PM
Joel.
Feb 28, 2009 11:26 AM
qwrty
Jul 23, 2008 04:18 PM
jdmbeegee
Oct 17, 2006 10:09 PM
JoshRambo
Jan 17, 2002 01:22 AM
